Zum Hauptinhalt wechseln
Samsung Galaxy Camera Lens or Motherboard Replacement
Keith Lipking
Keith Lipking und 3 weitere Mitwirkende
Zuletzt aktualisiert am March 13, 2021
25 Minuten
Mittel
Aus eins mach mehr
This guide will take you through the steps to replace the motherboard or the zoom lens. Both parts follow the same process until the very last step.
Was du brauchst
Werkzeuge
  1. Samsung Galaxy Camera Lens or Motherboard Replacement, Lens or Motherboard: Schritt 1, Bild 1 von 1
    • Gather your camera and tools. Also make sure that the battery is removed before proceeding.
    • Follow battery replacement guide through step three to remove the battery.
  2. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove all seven 4 millimeter long screws using the PH000 screwdriver bit.
  3. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 3, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use plastic opening tool to remove the cover on the non-lens side of the camera.
  4. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Open the battery compartment and remove the 2 screws. Also remove the screw from the bottom of the camera after pulling off the white sticker concealing it. Removing these screws releases the bottom of the display assembly.
    • Starting at the non-lens side of the camera, use plastic opening tool to pry screen away from main housing on all sides.
  5. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use plastic opening tool to pull connector away from motherboard.
    • Remove screen completely and set aside.
  6. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, disconnect the three connectors from the motherboard.
  7. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 3.5 mm long screws (red circle markers) using the PH000 screwdriver bit.
    • Remove the four 2 mm long screws (orange circle markers) using the PH000 screwdriver bit.
  8. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the three 3 mm long screws connecting the lens unit to the main housing using the PH000 screwdriver bit.
    • Carefully remove the lens and motherboard from main housing.
  9. Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 9, Bild 1 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 9, Bild 2 von 3 Samsung Galaxy Camera Lens or Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Remove stickers off of connectors.
    • Open latch door on connectors.
    • Separate lens from motherboard.
    • Now you may replace either motherboard or lens with new part.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team 2-3, Wilson Fall 2015 Mitglied von IUPUI, Team 2-3, Wilson Fall 2015
IUPUI-WILSON-F15S2G3
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Would love a video of this, as well.
David CrossmN - Antwort
Hey after you replace the motherboard do you just turn the camera on and it works?
Ive done it and some chinese characters show up in a dialog box...
Sam - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 3,567
