Samsung Galaxy Mega Front Facing Camera Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide instructs on how to replace the front facing camera.
Was du brauchst
Before starting, ensure device is completely turned off.
On the back of phone, locate the slot on the top left corner.
Insert plastic opening tool or fingernail and pull up on the back plate.
With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
Insert fingernail into the slot on bottom of battery and gently pull up.
Remove the battery.
Remove the 14 3.45 mm Phillips #000 screws from the assembly.
Gently, insert plastic opening tool into seam above the volume buttons of your phone.
Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
The device should easily come apart after the plastic opening tool is slid around the entire device.
Remove the one 2.55 mm Phillips #000 screw from top left of motherboard assembly.
3 weitere Personen haben diese Anleitung absolviert.
