Einleitung
Use this guide to remove or replace the motherboard on your Samsung Galaxy Note10+ 5G.
This guide uses steps written for the non-5G Note10+. Some images in this guide may show minor discontinuities. They shouldn’t affect the overall guide procedure.
Was du brauchst
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the top edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Disconnect the secondary interconnect cable from the daughterboard.
Use a spudger or your fingers to gently fold the secondary interconnect cable away from the battery.
Use a Phillips screwdriver to remove the four 4 mm screws securing the top plastic cover.
Use a pair of tweezers to pivot the top plastic cover up and off of the phone.
Use the pointed end of a spudger to disconnect the touch layer connector from the motherboard.
Disconnect the side button connector from the motherboard.
Use the point of a spudger to pry up and disconnect the 5G mmWave antenna connector from the motherboard.
Gently bend the cable away from the motherboard.
Use the pointed end of a spudger to disconnect the S-Pen charging coil connector from the motherboard.
Use the pointed end of a spudger to disconnect the display cable from the motherboard.
Use the pointed end of a spudger to pry up the motherboard enough to grip it with your fingers.
Remove the motherboard.
