Zum Hauptinhalt wechseln
Samsung Galaxy Tab 4 7.0 Motherboard Replacement
Briana Honeycutt
Briana Honeycutt und 13 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
30 Minuten
Mittel
The motherboard is the control center for the tablet and is one of the most crucial components. Unfortunately there are only a few components that you can replace on it. If your charge port or headphone jack are compromised, it will be necessary to replace the whole motherboard.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Einführungsvideo
  1. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using the bent tweezers, carefully pull the flat cables away from the connectors.
    • Do not bend the flat cables at the tips as they may become permanently deformed.
  4. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 4, Bild 1 von 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 4, Bild 2 von 3 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Using the plastic opening tool, gently pry the chip connections away from the motherboard.
  5. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use the Phillips 000 screwdriver to remove the remaining five 1.2 mm screws.
  6. Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 6, Bild 1 von 2 Samsung Galaxy Tab 4 7.0 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use extreme care while removing the motherboard to avoid damaging the component.
    • Remove the motherboard by rotating it away from the rest of the phone as shown in the first photo.
Abschluss
24 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-3, Remmell Fall 2015 Mitglied von USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Mitglieder
12 Anleitungen geschrieben
4 Kommentare
I would like to change my tab 4 motherboard as ic heated so what is the price of new board
Malik - Antwort
Do the replacement motherboards sold on ifixit come with the operating system installed or do you have to install a new operating system once you replace the motherboard?
Erich Reichard - Antwort
Good instructions but not complete. My replacement motherboard was delivered without the cameras. I had to remove the cameras from the old motherboard and install them in the new motherboard. Then install the new motherboard.
Richard Kaapuni - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 47
Insgesamt: 18,420
