Einleitung
A dead battery means that the tablet will not work. Before replacing the battery, make sure the device is unplugged and turned off.
Apply the heat gun around the edges of the tablet to melt the adhesive glue.
Apply the suction to the bottom or top right corner.
Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
Take the plastic opening tool around the tablet to remove the motherboard from the device.
At the bottom left of the battery, use the plastic opening tool to detach the lower press-fit connector of the black ribbon cable.
Using the plastic opening tool, detach the press-fit connector on the left side of the black ribbon cable.
Lift up the black ribbon cable to remove it.
Using the plastic opening tool, detach the orange ribbon cable connecting the battery to the motherboard.
Using the Phillips #000 Screwdriver, remove the four 2.74mm black screws around the edge of the battery.
The battery is now fully detached from the motherboard.
Lift up the battery to remove it from the motherboard.
2 weitere Nutzer haben diese Anleitung absolviert.
3 Kommentare
Le tuto est parfaitement clair et précis. Un grand Merci.
Néanmoins il faut reconnaître que cette opération n’est pas simple du tout et qu’elle n’est pas sans risque, même en étant très méticuleux.
Pour ouvrir la coque, il faut obligatoirement un minimum de matériel adapté et malgré cela, c’est une galère !
Pour info sur la Galaxy tab s2 votre tuto est faux. Merci j'ai cassé le haut de mon écran. Grace à un autre site jai pu voir qu'il faut enlever le capot arrière pour accéder à la batterie
