Samsung SCH-8500 Front Cover Replacement
Einleitung
Zu Schritt 1 der AnleitungInstalling the front cover of the phone.
Was du brauchst
Werkzeuge
Use a Philips #0 screwdriver to remove the two screws below the screen.
Using the spudger, separate the black speaker cover from the top part of the phone.
Gently remove the black speaker cover completely.
Remove the two screws, approximately 10 mm in length, behind the black speaker cover with the screwdriver.
Once the two screws are taken out, use the spudger to remove the front cover of the phone.
