Zum Hauptinhalt wechseln
Samsung SGH-A117 is a basic flip phone. This guide will describe the steps required for disassembling and reassembling the phone.
Was du brauchst
Werkzeuge
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
Dieser Teardown ist keine Reparaturanleitung. Um dein Samsung SGH-A117 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Samsung SGH-A117: Breakdown and Reassembly, Samsumg SGH-A117: Schritt 1, Bild 1 von 1
    • This is the Samsung SGH-A117.
  2. Samsung SGH-A117: Breakdown and Reassembly, Backside of the cellphone: Schritt 2, Bild 1 von 1
    • This is the back view following the removal of the back cover and battery.
  3. Samsung SGH-A117: Breakdown and Reassembly, Removing Screws: Schritt 3, Bild 1 von 1
    • Use a screwdriver to remove screws around the frame.
    • Use a PH00 size screw to operate this step.
    • The screws are extremely small. It is recommended to have a small container to keep track of the screws.
  4. Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: Schritt 4, Bild 1 von 2 Samsung SGH-A117: Breakdown and Reassembly, Removing the Back Cover: Schritt 4, Bild 2 von 2
    • Insert the spudger under the back cover at the marked locations and gently lift to remove the back cover.
    • The end of the phone closest to the hinge will require additional force to lift.
    • Be careful not to bend the cover during the removal process.
  5. Samsung SGH-A117: Breakdown and Reassembly, Separate Circuit Connector from Logic Board: Schritt 5, Bild 1 von 1
    • Use a spudger to gently lift the circuit connector from the logic board.
    • Be careful not to remove the circuit connector from the phone.
  6. Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: Schritt 6, Bild 1 von 2 Samsung SGH-A117: Breakdown and Reassembly, Lift Logic Board: Schritt 6, Bild 2 von 2
    • Use a spudger to lift the logic board and separate it from the main body of the phone.
    • It is recommended to lift from the bottom part of the logic board as shown in the picture.
    • Be careful not to lose the volume button, which is loosely attached to the logic board.
  7. Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: Schritt 7, Bild 1 von 2 Samsung SGH-A117: Breakdown and Reassembly, Remove Keypad: Schritt 7, Bild 2 von 2
    • Gently push the keyboard from the case as shown in the picture.
  8. Samsung SGH-A117: Breakdown and Reassembly, Layout of Disassembled Device: Schritt 8, Bild 1 von 1
    • 1 Case
    • 1 Keyboard
    • 1 Logic Board
    • 1 Volume Control
    • 1 Back Cover
    • 5 Screws
Justin
150 Reputation
2 Anleitungen geschrieben
Aristotle Mitglied von Aristotle
Community
5 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 893
