Zum Hauptinhalt wechseln
Scuf Instinct Pro Bumpers Replacement
Was du brauchst
  1. Scuf Instinct Pro Bumpers Replacement, Prepare your controller for disassembly: Schritt 1, Bild 1 von 2 Scuf Instinct Pro Bumpers Replacement, Prepare your controller for disassembly: Schritt 1, Bild 2 von 2
    • Unplug all cables from your controller before starting.
    • Completely power off your controller.
    • Due to the controller’s odd shape, it can be helpful to stabilize it as you work. To prevent damage, consider laying it on a soft surface like a cloth or towel.
    Frag FixBot
    Kommentar hinzufügen
  2. Scuf Instinct Pro Bumpers Replacement, Remove the faceplate: Schritt 2, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the faceplate: Schritt 2, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the faceplate: Schritt 2, Bild 3 von 3
    • Magnets secure the faceplace to the midframe.
    • Lift the top edge of the faceplate to release the magnets securing it.
    • Remove the faceplate.
    Frag FixBot
  3. Scuf Instinct Pro Bumpers Replacement, Remove the battery cover: Schritt 3, Bild 1 von 2 Scuf Instinct Pro Bumpers Replacement, Remove the battery cover: Schritt 3, Bild 2 von 2
    • Weak magnets and two clips along the bottom edge secure the battery cover to the controller.
    • Slide the battery cover away from the controller to remove it.
    Frag FixBot
  4. Scuf Instinct Pro Bumpers Replacement, Remove the batteries: Schritt 4, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the batteries: Schritt 4, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the batteries: Schritt 4, Bild 3 von 3
    • If your batteries are starting to corrode, clean the contacts and replace the batteries.
    • Use your fingers to remove the batteries.
    • During reassembly, insert the batteries so their positive (+) and negative () ends match up with the markings on the battery contacts.
    Frag FixBot
  5. Scuf Instinct Pro Bumpers Replacement, Heat the battery sticker: Schritt 5, Bild 1 von 2 Scuf Instinct Pro Bumpers Replacement, Heat the battery sticker: Schritt 5, Bild 2 von 2
    • The sticker in the battery recess hides a back cover screw.
    • If you don't care about damaging the sticker, you can puncture through the center and skip the next step.
    • Use a hair dryer to heat the sticker and soften the adhesive securing it.
    • The sticker can be peeled without heating, but you risk tearing it.
    Frag FixBot
  6. Scuf Instinct Pro Bumpers Replacement, Peel up the battery sticker: Schritt 6, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Peel up the battery sticker: Schritt 6, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Peel up the battery sticker: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use the point of a spudger to push up a corner of the sticker until you can grab it with a pair of blunt nose tweezers.
    • Use your tweezers to peel up the sticker until the back cover screw is accessible.
    Frag FixBot
  7. Scuf Instinct Pro Bumpers Replacement, Unfasten the midframe: Schritt 7, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Unfasten the midframe: Schritt 7, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Unfasten the midframe: Schritt 7, Bild 3 von 3
    FixMat
    $31.41
    • Use a T8 Torx screwdriver to remove five 9.3 mm‑long screws securing the midframe:
    • One back cover screw
    • Four screws on top of the midframe
    • Use a T6 Torx screwdriver to remove the two 9.3 mm‑long screws securing the midframe.
    Frag FixBot
  8. Scuf Instinct Pro Bumpers Replacement, Unclip the midframe: Schritt 8, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Unclip the midframe: Schritt 8, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Unclip the midframe: Schritt 8, Bild 3 von 3
    • Plastic clips secure the bottom edge of the midframe.
    • Insert the flat end of a spudger between the bottom edge of the midframe and back cover.
    • Pry the midframe up with the spudger to release the clips.
    • Continue prying along the bottom edge to release the remaining clips.
    • Don't try to remove the midframe from the back cover yet—a delicate ribbon cable connects them.
    Frag FixBot
  9. Scuf Instinct Pro Bumpers Replacement, Prop up the midframe: Schritt 9, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Prop up the midframe: Schritt 9, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Prop up the midframe: Schritt 9, Bild 3 von 3
    • Put a box or a stack of books to the right of the controller so you can prop up the midframe while disconnecting its ribbon cable.
    • Secure the back cover with one hand, and use your other hand to grip the midframe's left edge.
    • Lift the midframe and rotate it over the right edge of the back cover, so the midframe's right edge is on your workspace.
    • Prop the midframe up, being careful not to strain the ribbon cable.
    Frag FixBot
  10. Scuf Instinct Pro Bumpers Replacement, Reassembly information: Schritt 10, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Reassembly information: Schritt 10, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Reassembly information: Schritt 10, Bild 3 von 3
    • During reassembly:
    • Guide the battery connectors on the midframe through their slot in the back cover.
    • Make sure the contacts slide into their grooves in the battery recess. If they aren't in the correct spot, the controller won't receive power.
    Frag FixBot
  11. Scuf Instinct Pro Bumpers Replacement, Disconnect the midframe: Schritt 11, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Disconnect the midframe: Schritt 11, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Disconnect the midframe: Schritt 11, Bild 3 von 3
    • A very small rubber grommet secures the midframe's ribbon cable to a post on the right side of the back cover.
    • Use blunt nose tweezers to remove the grommet—don't lose it!
    Frag FixBot
  12. Scuf Instinct Pro Bumpers Replacement: Schritt 12, Bild 1 von 2 Scuf Instinct Pro Bumpers Replacement: Schritt 12, Bild 2 von 2
    • Use the flat end of a spudger or a clean fingernail to lift the hinged locking flap on the midframe cable ZIF connector.
    Frag FixBot
  13. Scuf Instinct Pro Bumpers Replacement: Schritt 13, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement: Schritt 13, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement: Schritt 13, Bild 3 von 3
    • Use blunt nose tweezers to grip the black pull tab on the midframe cable.
    • Lift the midframe cable off its post and pull it straight out of its socket.
    Frag FixBot
  14. Scuf Instinct Pro Bumpers Replacement, Remove the midframe: Schritt 14, Bild 1 von 1
    • Remove the midframe.
    Frag FixBot
  15. Scuf Instinct Pro Bumpers Replacement, Remove the USB‑C port cover: Schritt 15, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the USB‑C port cover: Schritt 15, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the USB‑C port cover: Schritt 15, Bild 3 von 3
    • The top of the USB‑C port cover is secured with a pair of plastic arms. The bottom is secured with plastic clips.
    • Rotate the underside of the USB‑C port cover up and away from the controller to release the bottom clips.
    • Unhook the plastic arms and remove the cover.
    • Hook the ends of the USB‑C cover's arms into their slots on either side of the Xbox button.
    • Rotate the cover downward until the bottom clips engage and the cover is flush with the bumpers.
    Frag FixBot
  16. Scuf Instinct Pro Bumpers Replacement, Unclip a bumper: Schritt 16, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Unclip a bumper: Schritt 16, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Unclip a bumper: Schritt 16, Bild 3 von 3
    • Tight plastic clips secure the outer edges of the bumpers. Unclipping them requires some force.
    • Insert the point of a spudger between the midframe and the inner edge of one of the clips.
    • Pry the clip outward until it comes off its post and the bumper is freed.
    Frag FixBot
  17. Scuf Instinct Pro Bumpers Replacement, Remove the bumpers: Schritt 17, Bild 1 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the bumpers: Schritt 17, Bild 2 von 3 Scuf Instinct Pro Bumpers Replacement, Remove the bumpers: Schritt 17, Bild 3 von 3
    • Use your fingers to rotate the other bumper away from the controller until the clip comes off its post.
    • Remove the bumpers.
    • Make sure the tabs on the midframe and bumpers go into their corresponding cutouts.
    • Hook one of the bumpers onto its post and push the other bumper into the midframe until its clip snaps into place.
    Frag FixBot
Abschluss
Spencer Day
191.025 Reputation
1.204 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.949 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 24
Letzte 30 Tage: 86
Insgesamt: 2,996
