Zum Hauptinhalt wechseln
Service door disassembly
Roberto Bartolacci
Roberto Bartolacci und eine weitere beteiligte Person
Zuletzt aktualisiert am January 25, 2020
5 Minuten
Leicht
Anleitung eines Community-Mitglieds
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Service door disassembly, Remove the battery: Schritt 1, Bild 1 von 3 Service door disassembly, Remove the battery: Schritt 1, Bild 2 von 3 Service door disassembly, Remove the battery: Schritt 1, Bild 3 von 3
    • Turn the laptop upside down and gently lay it down on a flat surface.
    • Slide the battery release latch to the right and the battery will pop up slightly.
    • While keeping the latch slid with one hand, grab the battery with the other hand and remove it by pivoting it upward.
    • At this point some users would turn the laptop upside down once again and press the power button a couple of times. They say that this should help dissipating all of the remaining electricity around the device. Up to you :)
  2. Service door disassembly, Remove the captive screw of the service door: Schritt 2, Bild 1 von 1
    • Remove the Phillips PM2.0×4.0 screw using a PH#00 screwdriver.
  3. Service door disassembly, Remove the service door: Schritt 3, Bild 1 von 3 Service door disassembly, Remove the service door: Schritt 3, Bild 2 von 3 Service door disassembly, Remove the service door: Schritt 3, Bild 3 von 3
    • With an opening tool pry off the tabs that secure the service door to the base enclosure. Start with the long edge.
    • Continue along the short edges.
    • Once you have pried the service door off as it is in pic#3, it will come out of the rear edge very easily.
  4. Service door disassembly, Identify the components: Schritt 4, Bild 1 von 1
    • RAM memory modules
    • HDD (Hard Disk Drive)
    • mSATA SSD slot
    • Wifi & BT module (Wireless card)
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 252
