Seville Classics MSC10166 PCB (Printed Circuit Board) Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will show you how to take apart the fan to remove the Printed Circuit Board.
Was du brauchst
Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
Remove the screws from the four corners of the circuit board.
Remove the circuit board from the top cover.
