Zum Hauptinhalt wechseln
Smartab STJR700 Charging Port Replacement
Thi Le
Thi Le und 4 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
1 Stunde
Mittel
Aus eins mach mehr
This guide will show you how to replace the charging port in a Smartab STJR700 tablet. After determining all options have been attempted and the tablet still doesn't charge, then refer to this repair guide. Prior to fixing the device, ensure that there aren't any other hardware issues. Hardware issues include damages in the charger and faulty battery.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Smartab STJR700 Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 1
    • Power off the device by holding down the lock button. Remove the case from the tablet and place it face down.
  2. Smartab STJR700 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Unscrew all four corner screws using the PH000 screwdriver head found in the iFixit kit.
  3. Smartab STJR700 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • CAUTION: Avoid touching the display.
    • Pry open the tablet using a metal spudger. Set aside the back panel.
  4. Smartab STJR700 Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Locate the charging port.
  5. Smartab STJR700 Charging Port Replacement: Schritt 5, Bild 1 von 2 Smartab STJR700 Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Unscrew all the labeled screws using the PH000 screwdriver head.
  6. Smartab STJR700 Charging Port Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Remove all pieces of tape using the tweezers provided in the iFixit kit.
    • Remove the two ribbon cables affixed to the camera.
  7. Smartab STJR700 Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Remove the motherboard component from the screen and display.
    • Because the charging port is soldered onto the motherboard, the motherboard must be replaced by one specifically made for the Smartab STJR700.
Abschluss
Thi Le
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S3-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,013
