Sony CDX-GT540UI CD Drive Replacement
Einleitung
Zu Schritt 1 der AnleitungThis will show one how to remove and replace the CD drive.
Before any repair work can be done one must remove the device for the vehicle. To do so follow this link to see a general vehicle removal of a stereo system.
Was du brauchst
Remove two 4.9mm Phillips #00screws on the front of the device.
Remove two 7.5mm Phillips #00screws on the front of the device.
Rotate device 90 degrees to either side.
Use the plastic opening tool to pry open the top and bottom tab respectively.
Repeat on opposite side.
Remove four 9.5mm Phillips #00 (black) screws from back panel.
Remove two 7.5mm Phillips #00 (black) screws from back panel.
Remove one 9.5mm Phillips #00 screw.
Rotate device 180 degrees and repeat step.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
This guide is listed as "difficult" yet only requires the use of a screwdriver and some prying tools. It would seem more appropriate to list it as "moderate" at most. I believe the motherboard guide has the same issue.
Also, you say PH#00 in the description of steps, but in the "tools" listing at the beginning of the guide, you said that a PH#0 was needed. These are not the same.
