Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-W120 LCD Screen Replacement
Christopher
Christopher und 4 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
10 Minuten
Schwierig
Falsche Werkzeuge
If the LCD display unit of your Sony Cyber-Shot DSC-W120 is damaged, this guide will walk you through the process of locating and removing it.
Was du brauchst
Werkzeuge
  1. Sony Cyber-Shot DSC-W120 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Unscrew the screws on the right side of the camera.
  2. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • With a plastic opening tool, gently lift and remove the silver piece on the right side of the camera.
  3. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic opening tool to carefully lift and remove the front case.
  4. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Gently pry the silver piece on the left side of the camera off with a plastic opening tool.
  5. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the three screws on the bottom of the camera.
  6. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Use a plastic opening tool to lift and remove the back case.
  7. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the screw located above the mode dial.
  8. Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-Shot DSC-W120 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Lift the LCD display from the rest of the camera.
    • Use tweezers to carefully separate the connecting tape.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Christopher
10 Reputation
1 Anleitung geschrieben
USF Tampa, Team 1-5, Leahy Fall 2014 Mitglied von USF Tampa, Team 1-5, Leahy Fall 2014
USFT-LEAHY-F14S1G5
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Hi, for step 8 the wider of the two ribbon cables is held by a black/dark grey clamp on the connector on the motherboard, it's best to release the clamp before pulling the cable out.
Do that by gently lifting it with a fingernail, it hinges on the screen side, it will rotate about 90 degrees to open. When reassembling it's simply the reverse, so push the cable in to the connector with the clamp open, when the cable is fully in there will be about 1mm of the gold connectors on the ribbon cable showing still, and then just clamp connector clamp shut but pushing it with your thumb.
Tony Neville - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 34
Insgesamt: 1,303
