Zum Hauptinhalt wechseln
Sony Cyber-Shot DSC-W830 Button Board Replacement
Addyson Salalila
Addyson Salalila und 4 weitere Mitwirkende
Zuletzt aktualisiert am December 24, 2016
5 Minuten
Mittel
In this guide, the camera will be disassembled and the button board will be removed and replaced. In order to reach this part of the camera, you have to disassemble the back panel.
Was du brauchst
Werkzeuge
  1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 2, Bild 1 von 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: Schritt 4, Bild 1 von 3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: Schritt 4, Bild 2 von 3 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: Schritt 4, Bild 3 von 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 5, Bild 1 von 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 5, Bild 2 von 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 5, Bild 3 von 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 6, Bild 1 von 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 6, Bild 2 von 3 Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 6, Bild 3 von 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: Schritt 7, Bild 1 von 2 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: Schritt 7, Bild 2 von 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-Shot DSC-W830 Button Board Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 17-1, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 41
Insgesamt: 1,512
