Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-HX1 Button Assembly Replacement
Brianna Greenlaw
Brianna Greenlaw und eine weitere beteiligte Person
Zuletzt aktualisiert am January 14, 2021
5 - 10 Minuten
Leicht
Removal and replacement of these buttons requires some previous disassembly and removal of the motherboard.
Was du brauchst
Werkzeuge
  1. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the surface you place the screen on is clean of debris and dust. Otherwise you risk scratching your screen.
    • Place the camera with the bottom facing you and the lens facing up.
  2. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: Schritt 2, Bild 1 von 1
    • Push down and away from the camera to the left on the indicated indentation in the battery cover. The compartment should slide open as shown.
  3. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: Schritt 3, Bild 2 von 2
    • Push the blue tab towards the camera body to the right, while simultaneously pulling out the battery.
    • The battery is not shown here. However, normally the battery would be in the displayed compartment.
  4. Sony Cyber-shot DSC-HX1 Button Assembly Replacement, Button Assembly: Schritt 4, Bild 1 von 1
    • On the top of the inside the battery compartment, remove the #00 6.0 mm Phillips screw.
  5. Sony Cyber-shot DSC-HX1 Button Assembly Replacement: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-HX1 Button Assembly Replacement: Schritt 5, Bild 2 von 2
    • Lift the button housing from its position on top of the camera.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 17-3, Forte Spring 2015 Mitglied von Cal Poly, Team 17-3, Forte Spring 2015
CPSU-FORTE-S15S17G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 947
