Sony Cyber-shot DSC-T1 CCD Sensor Module Replacement
Einleitung
Zu Schritt 1 der AnleitungIs your LCD screen acting strange? Replacing the CCD Sensor Module is a straight forward task that will increase the clarity of your screen.
Was du brauchst
Werkzeuge
Locate the battery door at the bottom of the camera.
Press down on the door and slide it back. The door will pop open.
Use a PH00 screwdriver and remove the six 2.9mm screws.
Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
The second picture shows what these tabs look like in their open positions.
2 weitere Personen haben diese Anleitung absolviert.
