Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-T1 CCD chip Replacement
Rosario
Rosario und 7 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
10 - 15 Minuten
Mittel
Follow this guide for the process of replacing the CCD chip, which is responsible for converting light into digital images. For safety reasons, battery should be first removed.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Sony Cyber-shot DSC-T1 CCD chip Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the cover on the bottom of the camera.
    • Slide the cover towards the back of the camera.
    • Be careful—the battery can slide out on its own.
  2. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the exposed battery.
    • If it is difficult to remove, flip over the camera and the battery will slide out.
  3. Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T1 CCD chip Replacement, CCD chip: Schritt 3, Bild 3 von 3
    • Locate and remove the 3mm screws on the bottom and sides of the camera with a JIS size #0 screwdriver.
  4. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 4, Bild 1 von 1
    • Pull the two halves of the camera apart.
    • Place the two halves down with the insides facing you.
  5. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 5, Bild 1 von 1
    • Find the two clips holding the motherboard to the black lens box.
    • Slide the plastic opening tool in between the ribbon and the black part of the clip, then flip it up. (If difficult, your fingernail can also be used)
  6. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 6, Bild 1 von 1
    • After releasing the clips, pull out the black lens box.
    • If the black lens box does not come out, go back to the previous step and make sure you released the correct clips.
  7. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 7, Bild 1 von 1
    • Locate and unscrew the two 3mm screws on the bottom of the black lens box with the JIS #0 screwdriver.
  8. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • With the tweezers remove the black tape to detach the chip from the lens box.
  9. Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 9, Bild 1 von 2 Sony Cyber-shot DSC-T1 CCD chip Replacement: Schritt 9, Bild 2 von 2
    • Grab the chip with your thumbs and carefully pull it off.
    • The copper tab will be glued to the lens box. Be careful not to rip it.
    • The attached copper ribbons are part of the CCD chip.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Rosario
48 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-35, Maness Spring 2012 Mitglied von Cal Poly, Team 7-35, Maness Spring 2012
CPSU-MANESS-S12S7G35
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 5,549
