Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-T1 Flash Module Replacement
iDeleted
iDeleted und 13 weitere Mitwirkende
Zuletzt aktualisiert am December 8, 2020
5 Minuten
Mittel
Anleitung eines Community-Mitglieds
Having problems with the camera flash? Replacing the Flash Module is easy!
Was du brauchst
Werkzeuge
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Cyber-shot DSC-T1 Flash Module Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Sony Cyber-shot DSC-T1 Flash Module Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the door that you opened in the previous step.
  3. Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 1 von 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 2 von 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: Schritt 3, Bild 3 von 3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Sony Cyber-shot DSC-T1 Flash Module Replacement: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-T1 Flash Module Replacement: Schritt 4, Bild 2 von 2
    • Use hands to gently pry the front casing away from the camera.
  5. Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: Schritt 5, Bild 1 von 2 Sony Cyber-shot DSC-T1 Flash Module Replacement, CCD Sensor Module: Schritt 5, Bild 2 von 2
    • Use the tip of a spudger to flip up the tab on the ZIF connector securing the motherboard ribbon cable.
    • The second picture shows what these tabs look like in their open positions.
  6. Sony Cyber-shot DSC-T1 Flash Module Replacement: Schritt 6, Bild 1 von 1
    • Grasp the CCD Sensor Module and remove it.
  7. Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: Schritt 7, Bild 1 von 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: Schritt 7, Bild 2 von 3 Sony Cyber-shot DSC-T1 Flash Module Replacement, Flash Module: Schritt 7, Bild 3 von 3
    • This camera houses a very strong capacitor (the black cylinder). Avoid touching anything around the two wires coming out of the top. Doing so will risk serious electric shock.
    • Carefully disengage the internal components from the casing by lifting at the bottom end and giving a gentle tug.
    • The components are still connected to the casing via cables, but they are much more maneuverable.
    • The flash module is shown on the right hand side.
  8. Sony Cyber-shot DSC-T1 Flash Module Replacement: Schritt 8, Bild 1 von 2 Sony Cyber-shot DSC-T1 Flash Module Replacement: Schritt 8, Bild 2 von 2
    • Use the tip of a spudger to flip up the tab on the ZIF connecter securing the motherboard ribbon cable.
    • Grasp the flash module by the bottom and remove it.
Abschluss
iDeleted
2.101 Reputation
39 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 2,369
