Zum Hauptinhalt wechseln
Sony Xperia TL Motherboard Replacement
Adam Giniger
Adam Giniger und 2 weitere Mitwirkende
Zuletzt aktualisiert am January 9, 2015
3 Minuten
Mittel
It is easy to access and if this component goes bad the phone will not turn on.
Was du brauchst
Werkzeuge
  1. Sony Xperia TL Motherboard Replacement, Remove Top Plastic Section: Schritt 1, Bild 1 von 3 Sony Xperia TL Motherboard Replacement, Remove Top Plastic Section: Schritt 1, Bild 2 von 3 Sony Xperia TL Motherboard Replacement, Remove Top Plastic Section: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Motherboard Replacement, Remove Bottom Plastic Section: Schritt 2, Bild 1 von 2 Sony Xperia TL Motherboard Replacement, Remove Bottom Plastic Section: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Motherboard Replacement, Unscrewing the Back Off: Schritt 3, Bild 1 von 3 Sony Xperia TL Motherboard Replacement, Unscrewing the Back Off: Schritt 3, Bild 2 von 3 Sony Xperia TL Motherboard Replacement, Unscrewing the Back Off: Schritt 3, Bild 3 von 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Motherboard Replacement, Battery: Schritt 4, Bild 1 von 3 Sony Xperia TL Motherboard Replacement, Battery: Schritt 4, Bild 2 von 3 Sony Xperia TL Motherboard Replacement, Battery: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Motherboard Replacement, Sony Xperia TL Auxiliary Cord Replacement: Schritt 5, Bild 1 von 2 Sony Xperia TL Motherboard Replacement, Sony Xperia TL Auxiliary Cord Replacement: Schritt 5, Bild 2 von 2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 Sony Xperia TL Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 Sony Xperia TL Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Adam Giniger
1.303 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 4-4, Brown Fall 2014 Mitglied von USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 546
