Zum Hauptinhalt wechseln
Sony Xperia XA1 Ultra Loudspeaker Replacement
Jacob Jung
Jacob Jung und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 29, 2018
7 Minuten
Leicht
This guide will show you how to remove the loudspeaker from your Sony Xperia XA1 Ultra. The loudspeaker needs to be replaced if sound is no longer emitted from your phone. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws, and a spudger is used to lift and remove components of the phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Sony Xperia XA1 Ultra Loudspeaker Replacement, Back Assembly: Schritt 1, Bild 1 von 2 Sony Xperia XA1 Ultra Loudspeaker Replacement, Back Assembly: Schritt 1, Bild 2 von 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 2, Bild 1 von 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 3, Bild 1 von 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 5, Bild 1 von 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 6, Bild 1 von 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Loudspeaker Replacement, Loudspeaker: Schritt 7, Bild 1 von 1
    • Remove the five 4mm T5 screws connecting the speaker to your phone.
  8. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 8, Bild 1 von 2 Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 8, Bild 2 von 2
    • Insert your iFixit Opening Tool underneath the speaker and gently lift up.
    • Once the speaker is slightly lifted, use your hands to remove the piece from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jacob Jung
1.429 Reputation
9 Anleitungen geschrieben
Cal Poly, Team S16-G3, Livingston Spring 2018 Mitglied von Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 29
Insgesamt: 1,017
