Zum Hauptinhalt wechseln
SteelSeries Stratus Duo Charging Port Replacement
Was du brauchst
  1. SteelSeries Stratus Duo Charging Port Replacement, Remove the sticker: Schritt 1, Bild 1 von 2 SteelSeries Stratus Duo Charging Port Replacement, Remove the sticker: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
    Frag FixBot
    Kommentar hinzufügen
  2. SteelSeries Stratus Duo Charging Port Replacement, Unscrew the back cover: Schritt 2, Bild 1 von 1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
    Frag FixBot
  3. SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: Schritt 3, Bild 1 von 3 SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: Schritt 3, Bild 2 von 3 SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: Schritt 3, Bild 3 von 3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
    Frag FixBot
  4. SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: Schritt 4, Bild 1 von 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: Schritt 4, Bild 2 von 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: Schritt 4, Bild 3 von 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    Frag FixBot
  5. SteelSeries Stratus Duo Charging Port Replacement: Schritt 5, Bild 1 von 2 SteelSeries Stratus Duo Charging Port Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
    Frag FixBot
  6. SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: Schritt 6, Bild 1 von 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: Schritt 6, Bild 2 von 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: Schritt 6, Bild 3 von 3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
    Frag FixBot
  7. SteelSeries Stratus Duo Charging Port Replacement, Remove the back cover assembly: Schritt 7, Bild 1 von 1
    • Remove the back cover assembly.
    Frag FixBot
  8. SteelSeries Stratus Duo Charging Port Replacement, Pry up the battery: Schritt 8, Bild 1 von 2 SteelSeries Stratus Duo Charging Port Replacement, Pry up the battery: Schritt 8, Bild 2 von 2
    • The battery is held in place by mild adhesive.
    • Insert the long edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and separate the adhesive.
    Frag FixBot
  9. SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: Schritt 9, Bild 1 von 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: Schritt 9, Bild 2 von 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: Schritt 9, Bild 3 von 3
    • Grab the battery with your fingers and lift it out of its recess to remove it.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • During reassembly make sure to align the battery and the back cover correctly.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
    Frag FixBot
  10. SteelSeries Stratus Duo Charging Port Replacement, Unscrew the plastic bracket: Schritt 10, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 7.2 mm-long screws securing the plastic bracket that holds the charging port and the Bluetooth/power buttons in place.
    Frag FixBot
  11. SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: Schritt 11, Bild 1 von 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: Schritt 11, Bild 2 von 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: Schritt 11, Bild 3 von 3
    • Use your fingers to push the plastic bracket downwards into the recess of the battery to loosen it.
    • Remove the plastic bracket.
    Frag FixBot
  12. SteelSeries Stratus Duo Charging Port Replacement, Remove the charging port: Schritt 12, Bild 1 von 1
    • Remove the charging port.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.930 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where can i get the replacement board? Stratus is not responding to my messages.
ryan olson - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 39
Insgesamt: 806
