Zum Hauptinhalt wechseln
Table Fan Blades Replacement
Cora Diehl
Cora Diehl und eine weitere beteiligte Person
Zuletzt aktualisiert am June 11, 2021
10 Minuten
Mittel
If your 6-8 inch Personal Table Fan has been lagging or the blades have broke. Use this guide to replace the blades in your fan.
Before using this guide, make sure your fan works when plugged in. If it does not, the blades are not the issue, the motor is and this guide will not fix the issue.
Before beginning, make sure to unplug your fan.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Table Fan Blades Replacement, Blades: Schritt 1, Bild 1 von 3 Table Fan Blades Replacement, Blades: Schritt 1, Bild 2 von 3 Table Fan Blades Replacement, Blades: Schritt 1, Bild 3 von 3
    • Use a prying tool to loosen the front cover.
    • After it is pried loose, remove the cover.
  2. Table Fan Blades Replacement: Schritt 2, Bild 1 von 1
    • Remove two 12.7 mm Phillips #2 screws from the back cover.
    • Take off the back cover.
  3. Table Fan Blades Replacement: Schritt 3, Bild 1 von 1
    • Remove two 38.1 mm Phillips #2 screws from the motor.
  4. Table Fan Blades Replacement: Schritt 4, Bild 1 von 3 Table Fan Blades Replacement: Schritt 4, Bild 2 von 3 Table Fan Blades Replacement: Schritt 4, Bild 3 von 3
    • While holding the back of the fan, pull the blades.
    • Take off the old blades and put them aside.
  5. Table Fan Blades Replacement: Schritt 5, Bild 1 von 1
    • Take the motor out.
  6. Table Fan Blades Replacement: Schritt 6, Bild 1 von 2 Table Fan Blades Replacement: Schritt 6, Bild 2 von 2
    • Clean all parts of the fan.
  7. Table Fan Blades Replacement: Schritt 7, Bild 1 von 2 Table Fan Blades Replacement: Schritt 7, Bild 2 von 2
    • Put the motor and back cover back on.
    • This can be done by following steps 2, 3, and 5 in reverse.
  8. Table Fan Blades Replacement: Schritt 8, Bild 1 von 1
    • Place the new blade onto the metal rod on the front of the fan.
    • Push the blades onto the rod so that it is sturdy.
    • Replace the front cover.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 24
Insgesamt: 2,054
