Zum Hauptinhalt wechseln
Table Lamp Cord Replacement
Aysha Vear
Aysha Vear und 7 weitere Mitwirkende
Zuletzt aktualisiert am February 20, 2023
Keine Schätzung
Mittel
Fehlende Angaben
This step-by-step guide teaches the users two procedures: removing and replacing an old lamp cord and attaching a new cord to the socket.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Table Lamp Cord Replacement, Cord: Schritt 1, Bild 1 von 2 Table Lamp Cord Replacement, Cord: Schritt 1, Bild 2 von 2
    • Required materials: AAMP rewire kit, light bulb (not pictured), lamp shade (optional).
    • The AAMP lamp rewire kit should include a new cord, a socket shell, a socket interior and bottle adaptors. (Refer the second image to view the contents of the kit).
  2. Table Lamp Cord Replacement: Schritt 2, Bild 1 von 1
    • Caution! Before removing the lightbulb, ensure that the lamp is unplugged.
    • Cut the old lamp wire using scissors.
    • Remove the cord from the lamp.
    • Dispose the cord.
  3. Table Lamp Cord Replacement: Schritt 3, Bild 1 von 2 Table Lamp Cord Replacement: Schritt 3, Bild 2 von 2
    • Thread the new wire through the hole on the bottom of the lamp. Pull it out through the top of the lamp base. (Refer the first image to get a better understanding.)
    • Place the old check ring on top of the lamp with the wire threaded through it. (Refer the second image to see the check ring.)
  4. Table Lamp Cord Replacement: Schritt 4, Bild 1 von 2 Table Lamp Cord Replacement: Schritt 4, Bild 2 von 2
    • Place the lock nut at the end of the lamp nipple and turn it clockwise.
    • Thread the lock nut a quarter of the way through the lamp nipple.
  5. Table Lamp Cord Replacement: Schritt 5, Bild 1 von 2 Table Lamp Cord Replacement: Schritt 5, Bild 2 von 2
    • Ensure that the lamp cord sticks through the top of the lamp base.
    • Insert the lamp nipple and the lock nut into the bottle, in such a way that one-fourth inch of the lamp nipple faces up.
  6. Table Lamp Cord Replacement: Schritt 6, Bild 1 von 1
    • Insert the socket in the lamp nipple.
    • Tighten the socket by turning it clockwise until it reaches the lock nut.
  7. Table Lamp Cord Replacement: Schritt 7, Bild 1 von 1
    • Pull either ends of the wire so that you have about 2-3 inches of the wire separated.
  8. Table Lamp Cord Replacement: Schritt 8, Bild 1 von 1
    • Tie an underwriter's knot in the two separated pieces of wire.
    • How to tie the knot: Form a loop using the first wire. Take the second wire and form a loop around the first. Pass the tail of the second wire through the loop of the first.
  9. Table Lamp Cord Replacement: Schritt 9, Bild 1 von 1
    • Check both the conductors at the end of the wire. Find the ribbed conductor and wrap it around the silver-colored screw. Connect the other conductor to the brass-colored screw.
    • Tighten both of the screws in a clockwise direction. Make sure the conductors are securely under the screw head.
  10. Table Lamp Cord Replacement: Schritt 10, Bild 1 von 2 Table Lamp Cord Replacement: Schritt 10, Bild 2 von 2
    • Place the socket shell (with paper liner) over the socket interior. Snap it into correct position. Listen for clicks to make sure that the shell is locked properly.
    • The socket should snap together to form one piece.
  11. Table Lamp Cord Replacement: Schritt 11, Bild 1 von 1
    • Caution: Be sure that the rewired lamp is not plugged at this step.
    • Insert the new light bulb into the socket. Plug the cord and turn it on.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Aysha Vear
195 Reputation
1 Anleitung geschrieben
University of Maine, Team 1-3, Diaz Fall 2015 Mitglied von University of Maine, Team 1-3, Diaz Fall 2015
UMAINE-DIAZ-F15S1G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 19
Letzte 30 Tage: 52
Insgesamt: 7,526
