Zum Hauptinhalt wechseln
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Shelby Kunz
Shelby Kunz und 8 weitere Mitwirkende
Zuletzt aktualisiert am December 9, 2023
5 Minuten
Leicht
If your computer is not recognizing any CD/DVD in the drive, you may have a malfunctioning CD/DVD drive. This installation guide will help you through replacing the CD/DVD drive on the Toshiba Satellite C655D-S5084.
Was du brauchst
Werkzeuge
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: Schritt 1, Bild 1 von 1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: Schritt 2, Bild 1 von 1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Shelby Kunz
69 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 2-20, Maness Spring 2013 Mitglied von Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 5,072
