Einleitung
Is your computer getting too hot to handle? Overheating is a sign that your cooling fan may not be working properly, which may cause further damage to your computer. This guide will help you through the replacement of the cooling fan in your Toshiba Satellite C655D-S5084.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn over device to view the underside of the laptop, with the battery closest to you. Unlock the switch on the right side of the battery.
With one hand, unlock and hold the switch on the left of the battery while sliding the battery toward yourself with your other hand to remove it.
Unscrew the 5.5 mm "F5" screw using the Phillips #0 screwdriver, and carefully remove the plastic cover.
Remove the 2.5 mm screw labeled "F3" inside the hard drive casing (on the small metal tab of the hard drive) using the Phillips #1 screwdriver.
Place your thumb on the large metal tab on the hard drive and slide toward yourself, away from its base attachment.
Use your finger to lift the large metal tab on the hard drive to remove completely.
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
Wedge a plastic opening tool between the laptop and the CD drive.
Gently pull the CD drive out.
Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
Remove all fourteen (14) 6.0 mm 'F6' screws from the back panel using the Phillips #1 screwdriver.
Using a Phillips #1 screwdriver, remove two additional 2.0 mm screws underneath where the CD drive was.
Then use a Phillips #1 screwdriver and a plastic opening tool to undo the two tabs in this location.
The base should be somewhat looser now. Work the slack around the base of the computer until all internal latches have been released.
Using a small tool (or small hands) remove the tabs holding the white ribbon in place.
Remove the wide black ribbon in the same manner as in the previous step. There are also some catches that must be released.
Remove the other white plug in the same manner as shown in the previous picture.
8 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
