Zum Hauptinhalt wechseln
Vornado Zippi Fan Thermal cutout Replacement
Albert Straub
Albert Straub und 3 weitere Mitwirkende
Zuletzt aktualisiert am June 26, 2024
Keine Schätzung
Mittel
Anleitung eines Community-Mitglieds
My Zippi fan stopped working after it fell over and its blades were held so that they could not rotate. The fan thus overheated and caused the thermal cutout to fail. This series shows how I opened the fan and replaced the thermal cutout.
Was du brauchst
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Vornado Zippi Fan Thermal cutout Replacement, Locate and remove side screws: Schritt 1, Bild 1 von 1
    • There are two obvious screws on the sides of the fan. These are of the "Phillips" variety and need to be removed.
    • Remove the wire base by simply pulling each side out of the plastic housing. They are only held in place by the springiness of the wire base.
  2. Vornado Zippi Fan Thermal cutout Replacement, Remove the hidden screw in the base: Schritt 2, Bild 1 von 1
    • All of the screws are of the "Phillips" variety. It takes a bit of fiddling to get the screwdriver blade to engage with the screw but then it backs right out. Just leave the screw behind the rubber bit as it would be a nightmare to get it out and we will need it there for reassembly anyway.
  3. Vornado Zippi Fan Thermal cutout Replacement, Carefully pry off the power knob and the front propeller: Schritt 3, Bild 1 von 1
    • Be careful not to ding up the plastics. I had to use quite a bit of force to get the propeller off.
  4. Vornado Zippi Fan Thermal cutout Replacement, Remove the remaining 4 screws holding the case together: Schritt 4, Bild 1 von 1
    • After pulling away both sides of the plastic case, remove the black plastic housing by removing the two screws that hold it in place.
  5. Vornado Zippi Fan Thermal cutout Replacement, Cut away the insulation around the thermal cutout: Schritt 5, Bild 1 von 1
    • Use a razor knife and carefully cut away the silicon insulation around the thermal cutout.
    • Note that the cutout is a 115 degree C 2 amp device. I replaced it with a Panasonic EYP-2BN110 which is available from DataAlchemy on Amazon Marketplace.
    • Clip the old unit out and melt a blob of solder on the wires that stick out. Then clip short the leads of the new thermal cutout so that they just reach the exposed wires.
    • Hold the thermal cutout as far away from the device as possible with needle-nose pliers as a heatsink so that the soldering iron doesn't blow the fuse and quickly solder the fuse in place.
    • Now thread a bit of electrical insulation around the cutout to cover the exposed wires. Do not use more than a layer or the cutout may not operate when it is needed.
  6. Vornado Zippi Fan Thermal cutout Replacement, Reassemble in the reverse order: Schritt 6, Bild 1 von 1
    • Now simply put all of the pieces back together in the reverse order that you took them apart. Here is my Zippi, good as new and ready for the hot summer.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Thank you, my thermal was fine but my zippi was making an annoying clicking sound - just the disassembly, lubrication of the motor shaft with PTFE and putting it back together fixed it and it's running at a nice white noise hum right now better than ever.
Jonathan Bell - Antwort
Thank you very much! I thought the motor had burnt out!
Idmi - Antwort
Thanks for the instructions on removal. My Zippi's shaft is making a lot of noise--seems like a bearing problem. Don't know how to fix.
Chien-sheng Tsai - Antwort
My Zippi fell off my nightstand and started making noise. This may not help everyone but I simply tightened the screws in the body to pull the sides in tighter and the sound went away. Do not overtighten as the screws may strip.
Albert Straub - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 17
Letzte 30 Tage: 43
Insgesamt: 3,734
