Wahl Chrome Pro Power Cord Replacement
Einleitung
Zu Schritt 1 der AnleitungThe power cord connects the clipper to a power supply. If the power cord wiring breaks due to repeated bending, the power cord may need replacement. Replacing a broken power cord makes sure the clippers receive the power needed to run the device.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
Remove the 13.0 mm Phillips #2 screw on the side of the device body.
This screw is located on the opposite side of the body from the switch.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the spring on the side of the body using tweezers.
