Wexford CT-166TF Plastic Casing Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide will show you how to remove the plastic casing so that it can be replaced.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Remove the knob by gripping it and pulling straight up. Use a spudger if it is difficult to grip.
Using the plastic opening tool, turn the device over and remove the black plastic covers over the four screw holes.
Remove 5 smaller screws visible through small holes between the base and the casing.
Remove the two screws attached to the white bar near the red light on the top of the front casing.
Eine weitere Person hat diese Anleitung absolviert.
