WowWee MiP Robot Speaker Replacement
Einleitung
Zu Schritt 1 der AnleitungThe MiP communicates with playful sounds. A malfunctioning speaker will greatly diminish the user experience. Use this guide to replace the speaker in your WowWee MiP robot.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Carefully pull the battery pack from the robot.
Remove the batteries from the battery pack.
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
Remove the eight 9.3 mm Phillips #1 screws from the back of the robot.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using precision tweezers, disconnect the following three bundles of wires:
Connecting the battery pack to the motherboard.
Connecting the power switch to the motherboard.
Connecting the speaker to the motherboard.
Remove the two 7.5 mm Phillips #1 screws holding the speaker bracket in place.
