WowWee MiP Robot Tire Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide is designed to help users remove MiP’s wheels. MiP has two wheels that are connected to its body with screws. If the wheels need replacement or cleaning, follow this guide.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Use a metal spudger to carefully pry off the hubcap without marring the plastic wheel or hubcap.
Separate the rubber tire from the rim.
Push the collar out to separate the plastic layers of the wheel.
5 weitere Personen haben diese Anleitung absolviert.
