Zum Hauptinhalt wechseln
Xbox One Elite Controller Series 2 linken Joystick ersetzen
Was du brauchst
Videoanleitungen
Abschluss
Um dein Gerät wieder zusammenzubauen, folge den Schritten dieser Anleitung in umgekehrter Reihenfolge.
6 weitere Personen haben diese Anleitung absolviert.
en de
100%
Fabian Neidhardt hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
@HectorNavarroMX
4.257 Reputation
26 Anleitungen geschrieben
10 Kommentare zur Anleitung
Does this work for the series 1 elite controller also?
Nicola - Antwort
Can we please get some insight to what the silver tape that is put over certain leads?
- What is the silver tape?
- What is the silver tape used for?
- Which leads are the silver tape covering?
- What happens if silver tape is not used?
Noah Adams - Antwort
It is called Kapton Tape. It is used to protect components from heat during the rework process. If you don't use it, there is a chance of damaging the components. Even though the damage may not be seen by the naked eye. Hope this helps!
Ken Stopczynski -
It is aluminum tape not kapton tape. It is covering a surface mount component mounted within the area of the pins you have to desolder to remove the analog stick. He is covering it up to protect it from the heat and also to keep it from desoldering and moving while replacing the analog stick.
Damon Rowan -
ma per caso accetti spedizioni, perché anche a me mi si è rotto così
Gabriel Pisciotta - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 32
Letzte 7 Tage: 182
Letzte 30 Tage: 1,016
Insgesamt: 47,413
