Einleitung
Use this guide to replace a worn-out or dead battery in your Xiaomi Mi Watch 2021.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your watch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You might need replacement adhesive to reattach the battery when reassembling the device.
Was du brauchst
Before starting the disassembly, turn off your watch.
Remove the four 3.2 mm-long T3 Torx screws on the back of the watch.
Insert the flat end of a spudger into the loudspeaker opening at the top edge of the rear case assembly.
Push the spudger upwards to create a small gap between the rear case assembly and the watch housing.
Insert your spudger into the gap and pry up the rear case assembly.
Carefully swing open the rear case assembly by folding the rear case to the side with the watch buttons.
Remove the 2.7 mm-long Phillips screw securing the metal bracket.
Use the flat end of a spudger to pry up and disconnect the rear case assembly connector from the motherboard.
Use the flat end of a spudger to pry up and disconnect the battery connector.
Insert an opening pick underneath the left edge of the battery.
Tilt down your opening pick to pry up the battery.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
hi,
where can i purchase the metal bezel/case replacement for S1 active? thanks
