Zum Hauptinhalt wechseln
Xiaomi Redmi Note 8 Pro Rear Glass Replacement
Was du brauchst
  1. Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Heat the rear glass: Schritt 1, Bild 1 von 1
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Insert an opening pick: Schritt 2, Bild 1 von 3 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Insert an opening pick: Schritt 2, Bild 2 von 3 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Insert an opening pick: Schritt 2, Bild 3 von 3
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the rear glass and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Slice the adhesive: Schritt 3, Bild 1 von 2 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Slice the adhesive: Schritt 3, Bild 2 von 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Slice the adhesive: Schritt 4, Bild 1 von 3 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Slice the adhesive: Schritt 4, Bild 2 von 3 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Slice the adhesive: Schritt 4, Bild 3 von 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. Xiaomi Redmi Note 8 Pro Rear Glass Replacement: Schritt 5, Bild 1 von 2 Xiaomi Redmi Note 8 Pro Rear Glass Replacement: Schritt 5, Bild 2 von 2
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Xiaomi Redmi Note 8 Pro Rear Glass Replacement: Schritt 6, Bild 1 von 2 Xiaomi Redmi Note 8 Pro Rear Glass Replacement: Schritt 6, Bild 2 von 2
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The camera cover and fingerprint assembly is still adhered to its back.
  7. Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Remove the rear glass: Schritt 7, Bild 1 von 3 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Remove the rear glass: Schritt 7, Bild 2 von 3 Xiaomi Redmi Note 8 Pro Rear Glass Replacement, Remove the rear glass: Schritt 7, Bild 3 von 3
    • Carefully lift to rear glass upwards whilst pressing down the camera cover with a finger.
    • The camera cover and fingerprint assembly should separate from the rear glass during this procedure. In case the adhesive is too strong, you can apply a heated iOpener to the camera cover for one to two minutes to loosen its adhesive.
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
Abschluss
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
7 weitere Personen haben diese Anleitung absolviert.
Dominik Schnabelrauch
228.969 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.415 Anleitungen geschrieben
3 Kommentare
Bien explicado, gracias
Carlos Andres de la Vega - Antwort
Had some trouble on both lower curved sides. It required a lot of pressure to keep the contact on and not lift a little.
I have used a rear glass from Aliexpress so it might be the glass itself but doubt it.
miroslav.radichev - Antwort
hi bro were did buy the rear glass
Thaj Yusuf - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 40
Letzte 30 Tage: 104
Insgesamt: 7,089
