Einleitung
You can use this guide if you have a cracked back cover for your ZTE Grand X Max Plus and want to replace it.
You can also use this as a guide to open your phone.
Was du brauchst
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
After the phone is heated, use the blue plastic opening tool on both sides of the phone.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
