Zum Hauptinhalt wechseln
ZTE Grand X Max Plus Battery Replacement
Jordano Baer
Jordano Baer und 2 weitere Mitwirkende
Zuletzt aktualisiert am September 23, 2021
25 Minuten
Mittel
Empfohlene Anleitung von Studierenden
If you have a dead battery and want to replace it, you can use this guide.
The guide will show you how to remove the back cover of the ZTE Grand X Max Plus and how to remove the battery.
Was du brauchst
Werkzeuge
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. ZTE Grand X Max Plus Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Battery Replacement: Schritt 2, Bild 1 von 2 ZTE Grand X Max Plus Battery Replacement: Schritt 2, Bild 2 von 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Battery Replacement: Schritt 3, Bild 1 von 2 ZTE Grand X Max Plus Battery Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Battery Replacement, Battery: Schritt 4, Bild 1 von 2 ZTE Grand X Max Plus Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pry the battery off.
    • The battery will be held down securely by glue, so it'll take quite a bit of sliding underneath to separate it from the compartment.
  5. ZTE Grand X Max Plus Battery Replacement: Schritt 5, Bild 1 von 3 ZTE Grand X Max Plus Battery Replacement: Schritt 5, Bild 2 von 3 ZTE Grand X Max Plus Battery Replacement: Schritt 5, Bild 3 von 3
    • Pull up the piece that is connected to the motherboard. You can pull it using your nails.
  6. ZTE Grand X Max Plus Battery Replacement: Schritt 6, Bild 1 von 2 ZTE Grand X Max Plus Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the battery.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jordano Baer
716 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S9-G4, Remmell Fall 2017 Mitglied von USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 3,068
