Zum Hauptinhalt wechseln
ZTE Grand X Max Plus Camera Replacement
Jordano Baer
Jordano Baer und 2 weitere Mitwirkende
Zuletzt aktualisiert am September 23, 2021
25 Minuten
Mittel
This guide contains the steps to remove the rear camera from the ZTE Grand X Max Plus.
If your camera is scratched or not working, you can follow these steps to replace it.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Grand X Max Plus Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Make sure you turn off your phone before starting.
    • Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Camera Replacement: Schritt 2, Bild 1 von 2 ZTE Grand X Max Plus Camera Replacement: Schritt 2, Bild 2 von 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Camera Replacement: Schritt 3, Bild 1 von 2 ZTE Grand X Max Plus Camera Replacement: Schritt 3, Bild 2 von 2
    • Carefully remove the cover from the phone.
  4. ZTE Grand X Max Plus Camera Replacement, Rear Camera: Schritt 4, Bild 1 von 2 ZTE Grand X Max Plus Camera Replacement, Rear Camera: Schritt 4, Bild 2 von 2
    • Remove the screws from the upper part of the phone using a screwdriver with a JIS #000 head. There are (6) six screws that should be removed.
  5. ZTE Grand X Max Plus Camera Replacement: Schritt 5, Bild 1 von 3 ZTE Grand X Max Plus Camera Replacement: Schritt 5, Bild 2 von 3 ZTE Grand X Max Plus Camera Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to remove the plastic piece that is protecting the motherboard.
  6. ZTE Grand X Max Plus Camera Replacement: Schritt 6, Bild 1 von 1
    • With a plastic opening tool, unclip the camera from the motherboard.
  7. ZTE Grand X Max Plus Camera Replacement: Schritt 7, Bild 1 von 3 ZTE Grand X Max Plus Camera Replacement: Schritt 7, Bild 2 von 3 ZTE Grand X Max Plus Camera Replacement: Schritt 7, Bild 3 von 3
    • After the camera is unclipped, remove it from the device.
Abschluss
Jordano Baer
716 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S9-G4, Remmell Fall 2017 Mitglied von USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 187
