ZTE Grand X Max Plus Motherboard Replacement
Einleitung
Zu Schritt 1 der AnleitungFollow the steps on this guide to replace the motherboard of the ZTE Grand X Max Plus.
To remove the motherboard, you will need to open the phone and remove the battery first. These steps are included in this guide.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
After the phone is heated, use the blue plastic opening tool on both sides of the phone.
Pull up the piece that is connected to the motherboard. You can pull it using your nails.
Use a screwdriver with a JIS #000 head to remove the (8) eight screws.
Use a plastic opening tool to remove the plastic piece in the upper part of the phone.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Hello I recently repaired the screen on this same device by changing th whole front screen assembly with its frame. Once I finished the repair the phone seemed to function normally but now the phone cant connect to any network and keeps on thinking its on airplane mode. What could this be related to?
