ZTE Jasper LTE Memory Card Replacement
Einleitung
Zu Schritt 1 der AnleitungThis guide shows you how to replace the memory card for the ZTE Jasper LTE phone. You might need to replace the memory card if the storage on the SD card is full, or if you are wanting to replace the memory card with a another memory card that can have more storage on it.
Was du brauchst
Werkzeuge
Insert the spudger into the bottom left corner of the phone.
Use the spudger to loosen the back cover.
Insert the black spudger near the bottom left of the battery. There will be an opening to easily to remove the battery.
Continuing to use tool, prop up the battery and remove it.
