Zum Hauptinhalt wechseln
ZTE ZMAX Z970 Volume Button Replacement
Burak Cengiz
Burak Cengiz und 2 weitere Mitwirkende
Zuletzt aktualisiert am October 4, 2021
1 - 3 Minuten
Mittel
A guide on the replacement of the volume buttons on a ZTE ZMAX Z970 smartphone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE ZMAX Z970 Volume Button Replacement, Battery: Schritt 1, Bild 1 von 2 ZTE ZMAX Z970 Volume Button Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
    • Pull out the trays.
  2. ZTE ZMAX Z970 Volume Button Replacement: Schritt 2, Bild 1 von 2 ZTE ZMAX Z970 Volume Button Replacement: Schritt 2, Bild 2 von 2
    • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
    • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  3. ZTE ZMAX Z970 Volume Button Replacement: Schritt 3, Bild 1 von 3 ZTE ZMAX Z970 Volume Button Replacement: Schritt 3, Bild 2 von 3 ZTE ZMAX Z970 Volume Button Replacement: Schritt 3, Bild 3 von 3
    • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  4. ZTE ZMAX Z970 Volume Button Replacement: Schritt 4, Bild 1 von 2 ZTE ZMAX Z970 Volume Button Replacement: Schritt 4, Bild 2 von 2
    • Remove the mid frame with the plastic opening tool.
  5. ZTE ZMAX Z970 Volume Button Replacement: Schritt 5, Bild 1 von 2 ZTE ZMAX Z970 Volume Button Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery from the motherboard.
  6. ZTE ZMAX Z970 Volume Button Replacement: Schritt 6, Bild 1 von 2 ZTE ZMAX Z970 Volume Button Replacement: Schritt 6, Bild 2 von 2
    • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
    • Once free from the glue, remove from device.
    • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  7. ZTE ZMAX Z970 Volume Button Replacement, Volume Button: Schritt 7, Bild 1 von 2 ZTE ZMAX Z970 Volume Button Replacement, Volume Button: Schritt 7, Bild 2 von 2
    • Peel off circuit board carefully.
    • The new part will need to be soldered onto the motherboard.
Abschluss
Burak Cengiz
480 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S17-G3, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 347
