iMac G5 20" Model A1076 PRAM Battery Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace your CR2032 PRAM battery.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
Push the spudger away from the AirPort card to disconnect the AirPort antenna.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Slightly lift the AirPort bracket off the logic board.
De-route the AirPort antenna through the slot in the AirPort bracket.
Use a spudger to slide the PRAM battery out from under its socket's metal clip.
Eine weitere Person hat diese Anleitung absolviert.
