Zum Hauptinhalt wechseln
iMac G5 20" Model A1076 Rear Panel Replacement
Walter Galan
Walter Galan und 5 weitere Mitwirkende
Zuletzt aktualisiert am April 23, 2024
5 Minuten
Sehr einfach
Remove the rear panel to gain access to the innards of your iMac.
Was du brauchst
Werkzeuge
  1. iMac G5 20" Model A1076 Rear Panel Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 Rear Panel Replacement: Schritt 2, Bild 1 von 2 iMac G5 20" Model A1076 Rear Panel Replacement: Schritt 2, Bild 2 von 2
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 10
Insgesamt: 10,914
