Zum Hauptinhalt wechseln
iPad 6 Wi-Fi Right Speaker Replacement
Was du brauchst
  1. iPad 6 Wi-Fi Right Speaker Replacement, Heat the left edge: Schritt 1, Bild 1 von 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
    Frag FixBot
    Kommentar hinzufügen
  2. iPad 6 Wi-Fi Right Speaker Replacement, Screen removal information: Schritt 2, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Screen removal information: Schritt 2, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Screen removal information: Schritt 2, Bild 3 von 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
    Frag FixBot
  3. iPad 6 Wi-Fi Right Speaker Replacement, Anti-Clamp instructions: Schritt 3, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Anti-Clamp instructions: Schritt 3, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Anti-Clamp instructions: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    Frag FixBot
  4. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 4, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 4, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 4, Bild 3 von 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Frag FixBot
  5. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 5, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 5, Bild 2 von 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Frag FixBot
  6. iPad 6 Wi-Fi Right Speaker Replacement, Insert an opening pick: Schritt 6, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Insert an opening pick: Schritt 6, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Insert an opening pick: Schritt 6, Bild 3 von 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
    Frag FixBot
  7. iPad 6 Wi-Fi Right Speaker Replacement, Separate the left adhesive: Schritt 7, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the left adhesive: Schritt 7, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the left adhesive: Schritt 7, Bild 3 von 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
    Frag FixBot
  8. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 8, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 8, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 8, Bild 3 von 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
    Frag FixBot
  9. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 9, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 9, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 9, Bild 3 von 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
    Frag FixBot
  10. iPad 6 Wi-Fi Right Speaker Replacement, Heat the top edge: Schritt 10, Bild 1 von 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
    Frag FixBot
  11. iPad 6 Wi-Fi Right Speaker Replacement, Separate the top left adhesive: Schritt 11, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the top left adhesive: Schritt 11, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the top left adhesive: Schritt 11, Bild 3 von 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
    Frag FixBot
  12. iPad 6 Wi-Fi Right Speaker Replacement, Separate the top adhesive: Schritt 12, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the top adhesive: Schritt 12, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the top adhesive: Schritt 12, Bild 3 von 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
    Frag FixBot
  13. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 13, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 13, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 13, Bild 3 von 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
    Frag FixBot
  14. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 14, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 14, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 14, Bild 3 von 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
    Frag FixBot
  15. iPad 6 Wi-Fi Right Speaker Replacement, Heat the right edge: Schritt 15, Bild 1 von 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
    Frag FixBot
  16. iPad 6 Wi-Fi Right Speaker Replacement, Separate the top right adhesive: Schritt 16, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the top right adhesive: Schritt 16, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the top right adhesive: Schritt 16, Bild 3 von 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
    Frag FixBot
  17. iPad 6 Wi-Fi Right Speaker Replacement, Separate the right adhesive: Schritt 17, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the right adhesive: Schritt 17, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the right adhesive: Schritt 17, Bild 3 von 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • Stop sliding once you reach five inches from the bottom of the iPad to avoid damaging the display cables.
    Frag FixBot
  18. iPad 6 Wi-Fi Right Speaker Replacement, Heat the bottom edge: Schritt 18, Bild 1 von 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
    Frag FixBot
  19. iPad 6 Wi-Fi Right Speaker Replacement, Separate the bottom left adhesive: Schritt 19, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the bottom left adhesive: Schritt 19, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the bottom left adhesive: Schritt 19, Bild 3 von 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
    Frag FixBot
  20. iPad 6 Wi-Fi Right Speaker Replacement, Separate the bottom adhesive: Schritt 20, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the bottom adhesive: Schritt 20, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the bottom adhesive: Schritt 20, Bild 3 von 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
    Frag FixBot
  21. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 21, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 21, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 21, Bild 3 von 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
    Frag FixBot
  22. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 22, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 22, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 22, Bild 3 von 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
    Frag FixBot
  23. iPad 6 Wi-Fi Right Speaker Replacement, Heat the right edge: Schritt 23, Bild 1 von 1
    Frag FixBot
  24. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 24, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 24, Bild 2 von 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
    Frag FixBot
  25. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 25, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 25, Bild 2 von 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
    Frag FixBot
  26. iPad 6 Wi-Fi Right Speaker Replacement, Separate the right adhesive: Schritt 26, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the right adhesive: Schritt 26, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Separate the right adhesive: Schritt 26, Bild 3 von 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
    Frag FixBot
  27. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 27, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 27, Bild 2 von 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
    Frag FixBot
  28. iPad 6 Wi-Fi Right Speaker Replacement, LCD: Schritt 28, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, LCD: Schritt 28, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, LCD: Schritt 28, Bild 3 von 3
    • Remove any tape obscuring the LCD screws.
    Frag FixBot
  29. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 29, Bild 1 von 1
    • Remove the four Phillips #00 4.3 mm screws securing the LCD.
    Frag FixBot
  30. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 30, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 30, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 30, Bild 3 von 3
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers. There may be glue around the screw holes that needs to be cut with a knife.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on its face to allow access to the display cables.
    • Set the LCD down on a soft, clean, lint-free surface.
    Frag FixBot
  31. iPad 6 Wi-Fi Right Speaker Replacement, Battery connector information: Schritt 31, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Battery connector information: Schritt 31, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement, Battery connector information: Schritt 31, Bild 3 von 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    Frag FixBot
  32. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 32, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 32, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 32, Bild 3 von 3
    • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
    • Leave the battery blocker in place as you work.
    Frag FixBot
  33. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 33, Bild 1 von 1
    • Remove the three 1.4 mm Phillips #000 screws from the display cable bracket.
    Frag FixBot
  34. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 34, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 34, Bild 2 von 2
    • Use the flat end of a spudger to gently pry the display cable bracket straight up from the logic board.
    • The display cable connector is adhered to the underside of the bracket, so don’t push the spudger too far under the bracket, or you may damage the connector.
    Frag FixBot
  35. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 35, Bild 1 von 1
    • Remove the LCD.
    Frag FixBot
  36. iPad 6 Wi-Fi Right Speaker Replacement, Front Panel Assembly: Schritt 36, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement, Front Panel Assembly: Schritt 36, Bild 2 von 2
    • Remove any tape covering the home button ribbon cable connector.
    Frag FixBot
  37. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 37, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 37, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 37, Bild 3 von 3
    • Use the flat end of a spudger to flip the tab on the home button ribbon cable ZIF connector upward.
    • Carefully pull the home button ribbon cable straight out of the ZIF connector.
    Frag FixBot
  38. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 38, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 38, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 38, Bild 3 von 3
    • Use a the flat end of a spudger or a fingernail to carefully pop the two digitizer cable connectors straight up from their sockets.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    • During reassembly, make sure that these connectors are completely seated in their sockets, or you may encounter display issues.
    Frag FixBot
  39. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 39, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 39, Bild 2 von 2
    • Carefully peel the home button ribbon cable up off of the adhesive holding it to the rear case.
    Frag FixBot
  40. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 40, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 40, Bild 2 von 2
    Polyimide Tape
    $9.95
    • Remove the front panel assembly.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit panels come with the proper insulation, and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    Frag FixBot
  41. iPad 6 Wi-Fi Right Speaker Replacement, Right Antenna: Schritt 41, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement, Right Antenna: Schritt 41, Bild 2 von 2
    • Insert a spudger under the antenna cable closest to the edge of the iPad and lift upward to disconnect the antenna cable connector.
    Frag FixBot
  42. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 42, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 42, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 42, Bild 3 von 3
    • There are two large pieces of tape wrapped around the right antenna cable, securing it to the rear case.
    • Peel the tape up from the rear case.
    • While peeling the antenna tape up, leave it in place on the antenna cable to aid with reassembly.
    Frag FixBot
  43. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 43, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 43, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 43, Bild 3 von 3
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure.
    • Carefully insert an opening pick between the speaker enclosure and the antenna cable bracket.
    • Slide the pick toward the home button to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
    Frag FixBot
  44. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 44, Bild 1 von 1
    • Remove the following Phillips #000 screws securing the right antenna:
    • One 2.3 mm screw
    • Two 1.4 mm screws
    Frag FixBot
  45. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 45, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 45, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 45, Bild 3 von 3
    • Insert the flat end of a spudger between the antenna and the speaker assembly.
    • Slide the spudger toward the home button to cut the foam adhesive securing the antenna.
    Frag FixBot
  46. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 46, Bild 1 von 1
    • Remove the right antenna from the iPad.
    Frag FixBot
  47. iPad 6 Wi-Fi Right Speaker Replacement, Right Speaker: Schritt 47, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement, Right Speaker: Schritt 47, Bild 2 von 2
    • Insert a spudger under the left antenna cable and lift upward to disconnect the antenna cable connector.
    Frag FixBot
  48. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 48, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 48, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 48, Bild 3 von 3
    • There are five pieces of tape wrapped around the left antenna cable covering the right speaker cable connector.
    • Fold the antenna cable out of the way.
    Frag FixBot
  49. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 49, Bild 1 von 2 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 49, Bild 2 von 2
    • A bend in the speaker cable makes it difficult to peel the tape up from the end.
    • Instead, grip the tape just under the speaker and peel it down, away from the edge of the case.
    • Be careful with your tweezers—only grab and peel the tape, and not the cable beneath.
    Frag FixBot
  50. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 50, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 50, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 50, Bild 3 von 3
    • Peel the tape toward the home button to uncover the speaker cable connector.
    Frag FixBot
  51. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 51, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 51, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 51, Bild 3 von 3
    • Use the pointed end of a spudger to flip up the retaining flap on the right speaker cable connector.
    • Slide the speaker cable straight out of its ZIF connector.
    Frag FixBot
  52. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 52, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 52, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 52, Bild 3 von 3
    • Remove the tape holding the speaker to the rear case.
    Frag FixBot
  53. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 53, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 53, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 53, Bild 3 von 3
    • Carefully peel the LCD buffer tape up off of the rear case.
    Frag FixBot
  54. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 54, Bild 1 von 1
    • Remove the 2.2 mm Phillips #000 screw securing the speaker to the rear case.
    Frag FixBot
  55. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 55, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 55, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 55, Bild 3 von 3
    • Insert a fingernail or the flat end of a spudger in the groove in the speaker housing, near the corner of the rear case.
    • Pull the speaker down, away from the corner of the case.
    Frag FixBot
  56. iPad 6 Wi-Fi Right Speaker Replacement: Schritt 56, Bild 1 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 56, Bild 2 von 3 iPad 6 Wi-Fi Right Speaker Replacement: Schritt 56, Bild 3 von 3
    • Use a spudger to help pull the speaker out from under the edge of the rear case.
    • Remove the right speaker from the iPad.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Arthur Shi
336.939 Reputation
849 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.946 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 88
Insgesamt: 2,851
