Zum Hauptinhalt wechseln
The first generation Honda CRV, produced from 1995 to 2001.
20 Fragen Alle anzeigen
Why my reverse (backlight) won't work?
When putting my 1999 Honda CRV in reverse no (R) display light on dash and rear lights don't work. I changed rear bulbs still don't work!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Kevin, is it standard or automatic?
von
It's automatic!
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
There is a switch on the column if its an automatic that you may need to change to get it to work again If its a standard then its a little more involved. You need to go under the vehicle and find the shift linkage and then look for the switch there. Hope this helps
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Where is the switch at, and how do I get to the switch on the column?
von
The switch for your Honda is on the transmission housing, nowhere near the column.
von
Hilfreichste Antwort
Kevin start off by checking the under dash fuse relay box fuse #19. Make sure it is still intact. After that you want to check the Back-Up light switch, which is located on the transmission housing. Disconnect the connectors from the switch. Use a multimeter and check for continuity between contact 1 and contact 2. there should only be continuity between those points when your gear selector is in "R". If it is not, replace it.
Bewertung 3
2 Kommentare:
I haven't change the part yet, maybe you could send a picture of this part on a CRV so I will know its location! Thanks
von
So what happened to the car, did you fix it sir kevin?
von
I'm curious also. My left turn signal started clicking twice the normal speed and then I found the left side back up light was burned out. First I'd bout the flasher relay because back in the seventies if your turn signal started acting up it was always the culprit. Sometimes I forget what year it is. lol Anyway I changed all of the back end bulbs and now neither back up light are working. I used Philips long-life for the brake and turn signal bulbs and Bosch long life for the back up bulbs. Naturally I can't help but wonder if I should have shelled out the extra twenty bucks for the Philips b.u. bulbs.
I just couldn't understand went those little bulbs cost so much.
Bewertung 0
Kevin, did you fix this issue?
Bewertung 0
1 Kommentar:
I’m curious cause mine is doing the same thing. I just bought it.
von
Antwort hinzufügen
Kevin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 50
Insgesamt: 14,721
