Zum Hauptinhalt wechseln
The HP EliteBook Folio 9470m is low-cost, lightweight design Notebook that comes with features similar to that which you would get from a high-end personal computer. Released February of 2013. Identified by model number HSTNN-I10C.
13 Fragen Alle anzeigen
Why can't I remove the battery?
I tried following the battery removal guide, but after sliding the battery latch till the red part is visible, I can't slide the battery out. I've used a credit card to slightly pry the bottom part thinking that it was a friction problem, but it still doesn't come out. What can be done about it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Chideria Ehirim download the service manual for your computer from here Page 46 has the instructions (just like you did) Make sure that the latch is slid right to the end. You should get the battery to slide out first. You may need a little extra force so try a small screwdriver between the case and the back (not the bottom) of the battery. It has to slide out first before you can lift it out.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I've tried this and the battery doesn't budge at all.
von
I wonder if the locks move when you move the latch. Do you feel any resistance?
von
Antwort hinzufügen
Chidera Ehirim wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 181
