Zum Hauptinhalt wechseln
My pc won't turn on
won't turn on
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
So many possibilities, but not enough information for community to help.
von
Einen Kommentar hinzufügen
1 Antwort
Basically there are few steps you can try:
  1. UNPLUG the laptop power adaptor from the power jack
  2. REMOVE the laptop battery from the laptop.
  3. OPEN the back cover of the laptop, if found/can see CMOS battery, REMOVE it too.
  4. PRESS and HOLD the power button for at least 10 seconds ( for fully decharge and clear the power within the laptop)
  5. PLUG back in the power adaptor, try to POWER ON the laptop and see
If it doesnt work, then you need to find professional technician to diagnostic thru the laptop or if you got experience, you can try to dismantle the laptop and check thru is there any fault on the motherboard, connector, or any components inside.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Kumneger abay wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 74
