Zum Hauptinhalt wechseln
Der Nintendo Game Boy Advance kam 2001 auf den Markt. Für Reparaturen braucht man keine besonderen Werkzeuge und keine Wärme.
20 Fragen Alle anzeigen
Pads to solder don't exist
Hi team,
I have a problem, I have no where to add solder... Two middle pads are not there. I tried to add solder there but didn't work.
It's a gameboy advance board and power switch component. Is there a solución for this?
Thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Those pads are damaged and are gone. Looks like someone else tried to repair this already and used too much heat. Or tried to remove it while there was still solder on it and so the pads broke.
The only way to fix this, is to trace the traces and repair them. Make a new trace to the power switch and that should do the trick. Only thing is, is that this will take time and it's not easy to do.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Gabo Walker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 27
