Zum Hauptinhalt wechseln
Google Pixel 10 Pro Fold Outer Screen Replacement
Was du brauchst
  1. Google Pixel 10 Pro Fold Outer Screen Replacement, Prepare your phone for disassembly: Schritt 1, Bild 1 von 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    Frag FixBot
    Kommentar hinzufügen
  2. Google Pixel 10 Pro Fold Outer Screen Replacement, Insert an opening pick: Schritt 2, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Insert an opening pick: Schritt 2, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Insert an opening pick: Schritt 2, Bild 3 von 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    Frag FixBot
  3. Google Pixel 10 Pro Fold Outer Screen Replacement, Separate the adhesive: Schritt 3, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Separate the adhesive: Schritt 3, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Separate the adhesive: Schritt 3, Bild 3 von 3
    • During the next three steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
    Frag FixBot
  4. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 4, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 4, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 4, Bild 3 von 3
    • Slide the pick around the top right corner and along the top edge of the screen.
    Frag FixBot
  5. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 5, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 5, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 5, Bild 3 von 3
    • Slide your pick down the left edge and around the bottom left corner to separate the remaining adhesive.
    Frag FixBot
  6. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 6, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 6, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 6, Bild 3 von 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the left edge of the screen and swing it over the right edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
    Frag FixBot
  7. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display cable bracket screws: Schritt 7, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display cable bracket screws: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • While the Pixel 10 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the three screws securing the display cable bracket:
    • One 1.8 mm‑long screw
    • Two 2.5 mm‑long screws
    Frag FixBot
  8. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display bracket: Schritt 8, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display bracket: Schritt 8, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the display bracket: Schritt 8, Bild 3 von 3
    • Use the point of a spudger to pry up the display bracket and release its clip from the bottom edge of the frame.
    • Remove the display bracket.
    Frag FixBot
  9. Google Pixel 10 Pro Fold Outer Screen Replacement, Disconnect the screen: Schritt 9, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Disconnect the screen: Schritt 9, Bild 2 von 2
    • When disconnecting press connectors, pry only at the gold outlines on the logic board.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Use the point of a spudger to pry up the display cable press connector.
    Frag FixBot
  10. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the screen: Schritt 10, Bild 1 von 1
    • Lift the screen off the frame and remove it.
    Frag FixBot
  11. Google Pixel 10 Pro Fold Outer Screen Replacement, End of disassembly: Schritt 11, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    Frag FixBot
  12. Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the old adhesive: Schritt 12, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the old adhesive: Schritt 12, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Remove the old adhesive: Schritt 12, Bild 3 von 3
    • Use a spudger, or your fingers, to remove the old outer screen adhesive on the frame.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
    • If your new outer screen has a liner covering the front camera cutout, remove it now.
    • If your new outer screen comes with pre-installed adhesive, skip here. Otherwise, follow the guide normally to install new adhesive.
    Frag FixBot
  13. Google Pixel 10 Pro Fold Outer Screen Replacement, Compare your new adhesive: Schritt 13, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Compare your new adhesive: Schritt 13, Bild 2 von 2
    • Before removing any liners, check if the outer screen adhesive matches the frame.
    • The clear liner should face the frame.
    Frag FixBot
  14. Google Pixel 10 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 14, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Apply the new adhesive: Schritt 14, Bild 2 von 2
    • Peel away the top half of the new adhesive strip from its clear liner and keep the liner folded before continuing.
    Frag FixBot
  15. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 15, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 15, Bild 2 von 2
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
    Frag FixBot
  16. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 16, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 16, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 16, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
    Frag FixBot
  17. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 17, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 17, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 17, Bild 3 von 3
    • While peeling away the rest of the clear liner, slowly lay the adhesive over the perimeter of the phone.
    Frag FixBot
  18. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 18, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 18, Bild 2 von 2
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
    Frag FixBot
  19. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 19, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 19, Bild 2 von 2
    • Use the point of a spudger to pry up the segmented tab on the bottom edge of the large blue liner.
    Frag FixBot
  20. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 20, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 20, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 20, Bild 3 von 3
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
    Frag FixBot
  21. Google Pixel 10 Pro Fold Outer Screen Replacement, Reconnect the outer screen: Schritt 21, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Reconnect the outer screen: Schritt 21, Bild 2 von 2
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
    Frag FixBot
  22. Google Pixel 10 Pro Fold Outer Screen Replacement, Place the display bracket: Schritt 22, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Place the display bracket: Schritt 22, Bild 2 von 2
    • Place the display bracket over its spot on the frame.
    Frag FixBot
  23. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 23, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 23, Bild 2 von 2
    • Use the point of a spudger to press down the display bracket and slide its clip under the bottom edge of the frame.
    Frag FixBot
  24. Google Pixel 10 Pro Fold Outer Screen Replacement, Install the display bracket screws: Schritt 24, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Install the display bracket screws: Schritt 24, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the three screws securing the display cable bracket:
    • If your new outer screen comes with pre-installed adhesive, remove the liner to expose its adhesive and skip here.
    Frag FixBot
  25. Google Pixel 10 Pro Fold Outer Screen Replacement, Expose the adhesive: Schritt 25, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement, Expose the adhesive: Schritt 25, Bild 2 von 2
    • Use tweezers to grip the pull tab of the secondary liner at the bottom left corner of the phone.
    Frag FixBot
  26. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 26, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 26, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 26, Bild 3 von 3
    • Peel the liner from the left and top edge of the phone.
    Frag FixBot
  27. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 27, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 27, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 27, Bild 3 von 3
    • While holding the screen over the frame, peel the liner from the right and bottom edge of the frame and expose the adhesive.
    Frag FixBot
  28. Google Pixel 10 Pro Fold Outer Screen Replacement, Secure the outer screen: Schritt 28, Bild 1 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Secure the outer screen: Schritt 28, Bild 2 von 3 Google Pixel 10 Pro Fold Outer Screen Replacement, Secure the outer screen: Schritt 28, Bild 3 von 3
    • Align the outer screen over the frame and press it into place.
    Frag FixBot
  29. Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 29, Bild 1 von 2 Google Pixel 10 Pro Fold Outer Screen Replacement: Schritt 29, Bild 2 von 2
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
    Frag FixBot
Abschluss
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 10 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
245.452 Reputation
1.203 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 36
Letzte 30 Tage: 160
Insgesamt: 742
