Einleitung
Use this guide to remove or replace the back cover on your Motorola Edge (2022).
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
You'll need replacement adhesive to complete this repair.
Was du brauchst
Heat an iOpener and apply it to the back cover's right edge for two minutes.
Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the pick along the right edge to slice the adhesive.
Leave the pick in the bottom right edge to prevent the adhesive from resealing.
Apply a heated iOpener to the back cover's bottom edge for two minutes.
Rotate the pick around the bottom right corner to slice the adhesive.
Slide the pick along the bottom edge to slice the adhesive.
Leave the pick in the bottom left edge to prevent the adhesive from resealing.
Slide the pick along the edge to slice the adhesive.
Leave the pick in the top left edge to prevent the adhesive from resealing.
To reassemble your device, follow the instructions in reverse order.
