Zum Hauptinhalt wechseln
Nintendo Switch 2 Left Joy-Con 2 Connector Replacement
Was du brauchst
  1. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Power off the console: Schritt 1, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Power off the console: Schritt 1, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Power off the console: Schritt 1, Bild 3 von 3
    • For your safety, discharge the battery below 25% before disassembling the console. This reduces the risk of a fire if the battery is damaged during the repair. If the battery is swollen, take appropriate precautions.
    • Remove any game cards and disconnect any cables, controllers, or other accessories from the console.
    • Power off the console by holding down the power button, selecting Power Options, then pressing Power Off.
    Frag FixBot
    Kommentar hinzufügen
  2. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the bottom screws: Schritt 2, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the bottom screws: Schritt 2, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.1 mm‑long screws on either side of the bottom USB-C port.
    • You can try a non-iFixit Phillips driver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the driver and twist slowly.
    Frag FixBot
  3. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the top screw: Schritt 3, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the top screw: Schritt 3, Bild 2 von 2
    • Use a JIS 00 driver to remove the 3.1 mm‑long screw on the top edge of the console (next to the ventilation cutouts).
    Frag FixBot
  4. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Heat the right side sticker: Schritt 4, Bild 1 von 1
    • The Switch 2 has stickers on either side that need to removed to access the screws securing the back cover. It's easy to damage the stickers during removal, but you can mitigate this by regularly reheating the stickers and working carefully.
    • Use a hair dryer or heat gun to heat the sticker on the right side of the console, labeled with a "+" symbol, until it's hot to the touch.
    • You can use the kickstand to prop the console up vertically for easier access.
    • If you're using a heat gun, set it to low to avoid melting the plastic edge of the console.
    Frag FixBot
  5. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Pry up the right side sticker: Schritt 5, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Pry up the right side sticker: Schritt 5, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Pry up the right side sticker: Schritt 5, Bild 3 von 3
    • The pointed end of the tweezers can damage the sticker from the underside, leaving a noticeable mark. If it's difficult to lift, apply more heat instead of using more force.
    • Slide one arm of angled tweezers underneath the sticker from its cutout around the right Joy‑Con 2 connector.
    • Gently pry up on the sticker until it starts to lift from the console.
    • Leave the tweezers in place to keep the sticker lifted.
    Frag FixBot
  6. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 6, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 6, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Jimmy
    $7.95
    • Insert the tip of a Jimmy into the gap formed between the long edge of the console and the sticker.
    • Gently pry up the sticker, working your way up the long edge until the top of the sticker is separated from the console.
    • Remove the tweezers once the sticker is lifted.
    • You can leave the Jimmy in place to hold the top of the sticker off the frame—if it falls back into its recess, repeat this procedure to lift it back up.
    Frag FixBot
  7. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Heat the right side sticker: Schritt 7, Bild 1 von 1
    • Reheat the bottom of the right side until it's hot to the touch.
    Frag FixBot
  8. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the right side sticker: Schritt 8, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the right side sticker: Schritt 8, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the right side sticker: Schritt 8, Bild 3 von 3
    • Carefully lift the sticker over the Joy‑Con 2 connector, then peel it up fully to remove it.
    Frag FixBot
  9. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left side sticker: Schritt 9, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left side sticker: Schritt 9, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left side sticker: Schritt 9, Bild 3 von 3
    • Repeat this procedure to remove the sticker along the left side of the console, labeled with a "-" symbol.
    Frag FixBot
  10. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the side screws: Schritt 10, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the side screws: Schritt 10, Bild 2 von 2
    • Use a JIS 00 driver to remove the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Frag FixBot
  11. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Open the kickstand: Schritt 11, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Open the kickstand: Schritt 11, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Open the kickstand: Schritt 11, Bild 3 von 3
    • Use your fingers to flip up the kickstand on the back of the console.
    • If there's a microSD Express card installed, remove it now before you continue to the next step.
    Frag FixBot
  12. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the back-side screws: Schritt 12, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the back-side screws: Schritt 12, Bild 2 von 2
    • Use a Y00 driver to remove the two 4.4 mm‑long screws in the kickstand cutout.
    Frag FixBot
  13. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Insert an opening pick: Schritt 13, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Insert an opening pick: Schritt 13, Bild 2 von 2
    • Insert an opening pick into the gap between the back cover and speaker cutout on the bottom edge of the console.
    Frag FixBot
  14. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 14, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 14, Bild 2 von 2
    • Slide the opening pick towards the USB-C port until it's underneath the screw hole next to the port.
    Frag FixBot
  15. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Insert a second opening pick: Schritt 15, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Insert a second opening pick: Schritt 15, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Insert a second opening pick: Schritt 15, Bild 3 von 3
    • Insert a second opening pick underneath the screw hole on the opposite side of the USB-C port, and slide it to the corner of the console.
    Frag FixBot
  16. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 16, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 16, Bild 2 von 2
    • Slide the first opening pick back to where it was first inserted.
    Frag FixBot
  17. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the back cover: Schritt 17, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the back cover: Schritt 17, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the back cover: Schritt 17, Bild 3 von 3
    • Be careful not to drop your console. Once the back cover pops up, the opening picks will fall out of place.
    • Hold the console with two hands. Rest your thumbs on the opening picks.
    • Push up on the opening picks to lift the back cover until it pops up above the USB-C port.
    Frag FixBot
  18. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 18, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 18, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 18, Bild 3 von 3
    • Lift the back cover up from the bottom edge and remove it.
    Frag FixBot
  19. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the lower antenna screws: Schritt 19, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the lower antenna screws: Schritt 19, Bild 2 von 2
    • Use a JIS 00 driver to remove the three 4.4 mm‑long silver screws securing the lower antenna.
    Frag FixBot
  20. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the lower antenna: Schritt 20, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the lower antenna: Schritt 20, Bild 2 von 2
    • Use tweezers or your fingers to remove the lower antenna.
    Frag FixBot
  21. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the upper antenna screws: Schritt 21, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the upper antenna screws: Schritt 21, Bild 2 von 2
    • Use a JIS 00 driver to remove the two screws securing the upper antenna:
    • One 4.4 mm‑long silver screw
    • One 4.6 mm‑long green screw
    Frag FixBot
  22. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the upper antenna: Schritt 22, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the upper antenna: Schritt 22, Bild 2 von 2
    • Use tweezers or your fingers to remove the upper antenna.
    Frag FixBot
  23. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the lower antenna cable: Schritt 23, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the lower antenna cable: Schritt 23, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the lower antenna cable: Schritt 23, Bild 3 von 3
    • Insert an arm of angled tweezers under the metal neck of the white interconnect cable coaxial connector (located beneath the lower antenna) and lift straight up to disconnect it.
    Frag FixBot
  24. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the remaining antenna cables: Schritt 24, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the remaining antenna cables: Schritt 24, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the remaining antenna cables: Schritt 24, Bild 3 von 3
    • Repeat this procedure to disconnect the three central coaxial connectors from the board.
    Frag FixBot
  25. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the MicroSD connector: Schritt 25, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the MicroSD connector: Schritt 25, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the MicroSD connector: Schritt 25, Bild 3 von 3
    • Use the flat end of a spudger to pry up and disconnect the MicroSD card reader press connector, located next to the bottom USB‑C port.
    Frag FixBot
  26. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the shield plate screws: Schritt 26, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the shield plate screws: Schritt 26, Bild 2 von 2
    • Use a JIS 00 driver to remove the seven screws securing the shield plate:
    • Two 6.2 mm‑long silver screws
    • Five 4.4 mm‑long silver screws
    Frag FixBot
  27. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Lift the shield plate: Schritt 27, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Lift the shield plate: Schritt 27, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Lift the shield plate: Schritt 27, Bild 3 von 3
    • Insert the flat end of a spudger between the shield plate and the processor's heat sink, next to the square (⛶) marking on the shield plate.
    • Twist the spudger to lift the shield plate and separate the thermal putty bonded to it. Keep lifting the shield plate until you don't feel resistance.
    Frag FixBot
  28. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 28, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 28, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 28, Bild 3 von 3
    • Lift the left edge of the shield plate to ensure it's fully separated from the thermal putty.
    • Gently set the shield plate back down.
    Frag FixBot
  29. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Unroute the gray antenna cable: Schritt 29, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Unroute the gray antenna cable: Schritt 29, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Unroute the gray antenna cable: Schritt 29, Bild 3 von 3
    • Insert one arm of angled tweezers underneath the gray antenna cable at the bottom-right corner of the console.
    • Lift the cable out of the black clip securing it to the frame.
    Frag FixBot
  30. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 30, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 30, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 30, Bild 3 von 3
    • Unroute the gray antenna cable from its channel along the right edge of the console.
    Frag FixBot
  31. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 31, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 31, Bild 2 von 2
    • Lift and slide the shield plate away from the right edge of the console until the gray antenna cable is completely free.
    Frag FixBot
  32. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the shield plate: Schritt 32, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the shield plate: Schritt 32, Bild 2 von 2
    • Pick up and remove the shield plate.
    Frag FixBot
  33. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the battery: Schritt 33, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the battery: Schritt 33, Bild 2 von 2
    • Insert the flat end of a spudger underneath the flat-topped battery connector, located next to the battery, and pry up to disconnect it.
    Frag FixBot
  34. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Clean the heat pipe: Schritt 34, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Clean the heat pipe: Schritt 34, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Clean the heat pipe: Schritt 34, Bild 3 von 3
    Arctic Silver ArctiClean
    $11.99
    • If you don't have replacement thermal putty, use the flat end of a spudger to distribute the old putty evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate, then skip this step.
    • Use the flat end of a spudger to scrape off the thermal putty on top of the copper heat pipe.
    • Apply high-concentration (90% or higher) isopropyl alcohol or thermal material remover to a cotton swab or lint-free cloth and wipe away any remaining thermal putty on both the heat pipe and shield plate.
    • Don't use a paper towel or rag, as they may scratch the shield plate.
    Frag FixBot
  35. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the left speaker: Schritt 35, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the left speaker: Schritt 35, Bild 2 von 2
    • Use tweezers or your fingers to firmly grip the left speaker cable's white JST connector and pull straight away from its socket to disconnect it.
    Frag FixBot
  36. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left speaker: Schritt 36, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left speaker: Schritt 36, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left speaker: Schritt 36, Bild 3 von 3
    • Lift the speaker out of its recess and route its cable out from beneath the battery cable.
    • Remove the left speaker.
    Frag FixBot
  37. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the left Joy-Con 2 connector: Schritt 37, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disconnect the left Joy-Con 2 connector: Schritt 37, Bild 2 von 2
    • Use the point of a spudger to flip up the locking flap on the left Joy-Con 2 connector cable ZIF connector, located beneath the battery on the console's board.
    Frag FixBot
  38. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 38, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 38, Bild 2 von 2
    • Use tweezers or your fingers to gently pull the cable out of its connector.
    Frag FixBot
  39. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 39, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 39, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 39, Bild 3 von 3
    • Use a JIS 00 driver to remove the 2.3 mm‑long black screw securing the left Joy-Con 2 connector cable's bracket.
    • Remove the bracket.
    Frag FixBot
  40. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Unroute the left Joy-Con 2 cable: Schritt 40, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Unroute the left Joy-Con 2 cable: Schritt 40, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Unroute the left Joy-Con 2 cable: Schritt 40, Bild 3 von 3
    • Unroute the left Joy-Con 2 cable from around the battery well.
    • The cable is secured to the frame with a small piece of adhesive.
    Frag FixBot
  41. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left Joy-Con 2 connector screws: Schritt 41, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left Joy-Con 2 connector screws: Schritt 41, Bild 2 von 2
    • Remove the two 3.2 mm‑long black screws securing the left Joy-Con 2 connector.
    Frag FixBot
  42. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left Joy-Con 2 connector: Schritt 42, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left Joy-Con 2 connector: Schritt 42, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Remove the left Joy-Con 2 connector: Schritt 42, Bild 3 von 3
    • Grab the left Joy-Con 2 connector and carefully pull its cable out of the frame.
    • Remove the left Joy-Con 2 connector.
    Frag FixBot
  43. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Disassembly complete: Schritt 43, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    Frag FixBot
  44. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the left Joy‑Con 2 connector: Schritt 44, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the left Joy‑Con 2 connector: Schritt 44, Bild 2 von 2
    • Route the left Joy‑Con 2 connector cable through its slot in the frame until the connector itself is aligned with its screw holes.
    Frag FixBot
  45. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 45, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 45, Bild 2 von 2
    • Use a JIS 00 driver to install the two 3.2 mm‑long black screws securing the left Joy‑Con 2 connector.
    Frag FixBot
  46. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Route the left Joy‑Con 2 cable: Schritt 46, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Route the left Joy‑Con 2 cable: Schritt 46, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Route the left Joy‑Con 2 cable: Schritt 46, Bild 3 von 3
    Tesa 61395 Tape
    $2.95
    • Stick the cable onto its adhesive securing it to the frame.
    • If the adhesive got lost or damaged, replace it with a piece of thin, double-sided tape.
    • Route the connector's cable beneath the battery cable.
    Frag FixBot
  47. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 47, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 47, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 47, Bild 3 von 3
    • Align the cable's bracket with its posts and set it into the frame.
    • Use a JIS 00 driver to install the 2.3 mm‑long black screw securing the bracket.
    Frag FixBot
  48. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the left Joy‑Con 2 cable: Schritt 48, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the left Joy‑Con 2 cable: Schritt 48, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the left Joy‑Con 2 cable: Schritt 48, Bild 3 von 3
    • Use tweezers to insert the left Joy‑Con 2 connector cable into its ZIF connector on the board until it's fully seated.
    • Flip the hinged locking flap down to secure the cable.
    Frag FixBot
  49. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the left speaker: Schritt 49, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the left speaker: Schritt 49, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the left speaker: Schritt 49, Bild 3 von 3
    • Set the left speaker in its recess and route its cable beneath the battery cable.
    Frag FixBot
  50. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the left speaker: Schritt 50, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the left speaker: Schritt 50, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the left speaker: Schritt 50, Bild 3 von 3
    • Align the left speaker cable's white JST connector with its socket on the board.
    • Use tweezers or your fingers to fully seat the connector into its socket.
    Frag FixBot
  51. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the battery: Schritt 51, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the battery: Schritt 51, Bild 2 von 2
    • Align the battery connector over its socket on the board.
    • Use your finger or the flat end of a spudger to press the battery connector onto its socket until it's fully seated.
    Frag FixBot
  52. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Apply thermal putty: Schritt 52, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Apply thermal putty: Schritt 52, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Apply thermal putty: Schritt 52, Bild 3 von 3
    iFixit Thermal Putty
    $9.95
    • Apply a line of new thermal putty down the center of the heat pipe, roughly the thickness of a pea.
    Frag FixBot
  53. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Route the gray antenna cable: Schritt 53, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Route the gray antenna cable: Schritt 53, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Route the gray antenna cable: Schritt 53, Bild 3 von 3
    • Hold the top‑right corner of the shield plate above the top‑right corner of the console.
    • Route the gray antenna cable underneath the black hook near the top corner of the frame.
    Frag FixBot
  54. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Lower the shield plate: Schritt 54, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Lower the shield plate: Schritt 54, Bild 2 von 2
    • Lower the shield plate into place and align it with its screw holes.
    Frag FixBot
  55. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Finish routing the gray antenna cable: Schritt 55, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Finish routing the gray antenna cable: Schritt 55, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Finish routing the gray antenna cable: Schritt 55, Bild 3 von 3
    • Route the gray antenna cable down its channel on the right edge of the frame.
    Frag FixBot
  56. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 56, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 56, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 56, Bild 3 von 3
    • Press the gray antenna cable into its groove at the bottom of its channel, and continue routing until it's secured to the clip at the bottom of the frame.
    Frag FixBot
  57. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the shield plate screws: Schritt 57, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the shield plate screws: Schritt 57, Bild 2 von 2
    • Use a JIS 00 driver to install the seven screws securing the shield plate:
    Frag FixBot
  58. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the MicroSD connector: Schritt 58, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the MicroSD connector: Schritt 58, Bild 2 von 2
    • Use your finger or the flat end of a spudger to press the MicroSD card reader press connector onto its socket on the board.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Frag FixBot
  59. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the antenna cables: Schritt 59, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the antenna cables: Schritt 59, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Connect the antenna cables: Schritt 59, Bild 3 von 3
    • Use tweezers to hold the lower antenna coaxial connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head instead of using more force.
    • Repeat this process to connect the three central coaxial connectors to their respective sockets.
    • The black cable connects to the socket closest to the fan, the white to the middle, and the gray the furthest away.
    Frag FixBot
  60. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the upper antenna: Schritt 60, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the upper antenna: Schritt 60, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the upper antenna: Schritt 60, Bild 3 von 3
    • Use tweezers or your fingers to align the upper antenna with its screw holes and black alignment pegs and set it into place.
    • Use a JIS 00 driver to install the two screws securing the upper antenna:
    Frag FixBot
  61. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the lower antenna: Schritt 61, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the lower antenna: Schritt 61, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the lower antenna: Schritt 61, Bild 3 von 3
    • Use tweezers or your fingers to align the lower antenna with its screw holes and gray alignment pegs and set it into place.
    • Use a JIS 00 driver to install the three 4.4 mm‑long screws securing the lower antenna.
    Frag FixBot
  62. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Prepare the back cover: Schritt 62, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Prepare the back cover: Schritt 62, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Prepare the back cover: Schritt 62, Bild 3 von 3
    • Fully pull out the game card tray.
    • Double-check the power and volume buttons to ensure they're seated correctly. If the rubber membrane beneath the buttons is out of place, ensure it's aligned with its pegs.
    • Check the microphone to ensure it's fully seated in its slot in the frame.
    Frag FixBot
  63. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the back cover: Schritt 63, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the back cover: Schritt 63, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the back cover: Schritt 63, Bild 3 von 3
    • Align the top of the back cover with the top of the console.
    • Set the top edge of the back cover into place, checking the buttons and ports to ensure they're aligned properly. If they aren't, lift the back cover and try again.
    • Press along the top edge to fasten the clips securing the back cover to the console.
    Frag FixBot
  64. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 64, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 64, Bild 2 von 2
    • Squeeze the rest of the back cover and console together to fasten the clips.
    Frag FixBot
  65. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the back-side screws: Schritt 65, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the back-side screws: Schritt 65, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the back-side screws: Schritt 65, Bild 3 von 3
    • Use a JIS 00 driver to install the three 3.1 mm‑long screws securing the back cover: one on the top edge of the console, and two on either side of the bottom USB-C port.
    • Use a Y00 driver to install the two 4.4 mm‑long screws in the kickstand cutout.
    Frag FixBot
  66. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the side screws: Schritt 66, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the side screws: Schritt 66, Bild 2 von 2
    • Install the two 3.6 mm‑long gold screws on each side of the console (four in total).
    Frag FixBot
  67. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Test the console: Schritt 67, Bild 1 von 2 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Test the console: Schritt 67, Bild 2 von 2
    • Power on the console and test functionality to ensure it's working as expected.
    Frag FixBot
  68. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the stickers: Schritt 68, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the stickers: Schritt 68, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement, Install the stickers: Schritt 68, Bild 3 von 3
    • Align the right side sticker with its recess. Ensure the cutout in the sticker is aligned with the Joy-Con connector.
    • Set the sticker into its recess, first on one side, then the other.
    • Use your finger or the flat end of a spudger to press the sticker into place.
    • If the sticker isn't sticking well, apply heat after you press it into place.
    Frag FixBot
  69. Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 69, Bild 1 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 69, Bild 2 von 3 Nintendo Switch 2 Left Joy-Con 2 Connector Replacement: Schritt 69, Bild 3 von 3
    • Repeat this procedure to install the left side sticker.
    Frag FixBot
Abschluss
You finished fixing your Switch 2!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch 2 Answers Community for help.
Eine weitere Person hat diese Anleitung absolviert.
Nick Schultz
57.229 Reputation
316 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 24
Letzte 30 Tage: 102
Insgesamt: 1,030
