Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Huawei Mate 20 Pro zu reparieren, verwende unsere Fehlerbehebungsseite.
    1. Huawei Mate 20 Pro Teardown, Huawei Mate 20 Pro Teardown: Schritt 1, Bild 1 von 3 Huawei Mate 20 Pro Teardown, Huawei Mate 20 Pro Teardown: Schritt 1, Bild 2 von 3 Huawei Mate 20 Pro Teardown, Huawei Mate 20 Pro Teardown: Schritt 1, Bild 3 von 3
      • Here's what the Mate 20 Pro brings to the ring:
      • 6.39" AMOLED display with a resolution of 3120 × 1440 (~538 ppi)
      • Huawei Kirin 980 chipset: Mali-G76 MP10 GPU and an octa-core CPU (2x 2.6 GHz Cortex-A76 cores, 2x 1.92 GHz Cortex-A76 cores, and 4x 1.8 GHz Cortex-A55 cores)
      • Triple rear cameras: 40 MP ƒ/1.8, 20 MP ƒ/2.2, and 8 MP ƒ/2.4 lens with 5x optical zoom
      • 24 MP ƒ/2.0 selfie cam
      • IP68 dust/water ingress rating
      • Android 9.0 (PIE)
      • Facial recognition hardware, and an under-display fingerprint sensor
      Frag FixBot
      Kommentar hinzufügen
    2. Huawei Mate 20 Pro Teardown: Schritt 2, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 2, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 2, Bild 3 von 3
      • Face to face with Huawei's champion from last season, the Mate 20 Pro sports a newly notched, curved display.
      • This notch grew a little compared to that of the P20 Pro, making space for the new sensors needed for the 3D face unlock feature.
      • The Mate 20 Pro swaps out the rear fingerprint sensor for a third camera. But is three enough to keep up with the competition?
      • Our Mate 20 Pro is dressed up in the industry-standard glass sandwich, but the rear glass isn't quite as standard as it looks. Huawei applied a non-slip, fingerprint-resistant coating to help prevent slippery accidents.
      • The Mate 10 Pro's loudspeaker holes give way to the the SIM and NM card tray in the Mate 20 Pro.
      Frag FixBot
    3. Huawei Mate 20 Pro Teardown: Schritt 3, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 3, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 3, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      Suction Handle
      $2.95
      • Undaunted by a fragile rear glass panel thanks to recent teardowns of glue-filled competitors, we grab our heat gun and get to work.
      • Some heat helps the Mate 20 Pro to relax before our standard tools finish the job!
      • Thanks to the relocated fingerprint reader, there's no danger of tearing delicate flex cables while removing the rear cover.
      Frag FixBot
    4. Huawei Mate 20 Pro Teardown: Schritt 4, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 4, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 4, Bild 3 von 3
      • We just got here and we're already facing one of the Mate 20 Pro's new features—the bi-directional wireless charging coil.
      • The Mate 20 Pro's charging coil is both a transmitter and a receiver. Huawei wants you to use it to charge their AirPods competitor, Freepods.
      • Eight screws later, we remove the midframe assembly, which is home to the wireless charging coil, the NFC antenna and the dual-LED dual-tone flash.
      Frag FixBot
    5. Huawei Mate 20 Pro Teardown: Schritt 5, Bild 1 von 2 Huawei Mate 20 Pro Teardown: Schritt 5, Bild 2 von 2
      • At first glance, the motherboard looks free to jump right out, but a closer look reveals nine flex cables holding it in place, plus an antenna cable.
      • Like the P20 Pro, the Mate 20 Pro sticks to a relatively small motherboard, leaving room for a wider battery.
      • With the 3D face unlock hardware and the triple rear camera taking up more motherboard space than usual, Huawei had to cut some camera holes and change the layout a bit.
      • After prying away some loving arms flex cables, we manage to remove the motherboard along with the rear cameras.
      Frag FixBot
    6. Huawei Mate 20 Pro Teardown: Schritt 6, Bild 1 von 2 Huawei Mate 20 Pro Teardown: Schritt 6, Bild 2 von 2
      Spudger
      $2.99
      • ...which are easily removed after disconnecting two additional flex cables. Praise our good old friend the spudger!
      • The Mate 20 Pro has three rear cameras:
      • Top right: 40 MP, ƒ/1.8, 27 mm-equivalent wide angle lens
      • Bottom right: 20 MP, ƒ/2.2, 16 mm-equivalent ultra wide angle lens
      • Bottom left: 8 MP, ƒ/2.4, 80 mm-equivalent telephoto lens with 5x optical zoom
      • The P20 Pro's monochromatic camera is ditched for an ultra wide angle lens, ideal for landscape and macro shots (at a minimum focal distance of 2.5 cm).
      • Even with three cameras, Huawei says the brains behind this hardware is what will really make your images shine.
      Frag FixBot
    7. Huawei Mate 20 Pro Teardown: Schritt 7, Bild 1 von 2 Huawei Mate 20 Pro Teardown: Schritt 7, Bild 2 von 2
      • With the cameras out of the way, the motherboard takes center stage. Here's what it has to offer:
      • Toshiba THGAF8T0T43BAIR 128 GB Universal Flash Storage
      • HiSilicon Hi6421 power management IC
      • Skyworks SKY78130-21 front-end module for WCDMA/LTE bands 8/12/13/20/26/27
      • Skyworks SKY78132-52 front-end module for WCDMA/LTE bands 7/30/40/41
      • Skyworks SKY78131-21 front-end module for WCDMA/LTE bands 1/2/3/4/25/34/39
      • Skyworks 7360-2A 04115.1 1821 MX RF module
      • HiSilicon Hi6422 envelope tracker
      Frag FixBot
    8. Huawei Mate 20 Pro Teardown: Schritt 8, Bild 1 von 2 Huawei Mate 20 Pro Teardown: Schritt 8, Bild 2 von 2
      • On the backside we found:
      • SKhynix H9HKNNNEBMBUDR-NEH LPDDR4 (likely with Huawei Kirin 980 layered underneath)
      • NXP Semiconductor PN80T NFC controller w/ secure element
      • HiSilicon Hi1103 Wi-Fi chipset
      • HiSilicon Hi6363 RF transceiver
      • Texas Instruments TPS1879C1 display power management (likely)
      • ON Semiconductor FSA4476 USB type-C analog switch
      • ON Semiconductor NLAS2750 dual DPDT analog switch
      Frag FixBot
    9. Huawei Mate 20 Pro Teardown: Schritt 9, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 9, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 9, Bild 3 von 3
      • We snoop around the notch area and pull out the familiar-looking front camera / 3D face unlock assembly. It doesn't seem to completely mate up with what Huawei showed during their launch event, but our best guesses include:
      • Dot projector
      • 24 MP, ƒ/2.0, 26 mm-equivalent lens, borrowed from the P20 series
      • Rangefinder / proximity sensor
      • Flood illuminator
      • Ambient light sensor
      • IR camera
      • Rectangle of mystery
      Frag FixBot
    10. Huawei Mate 20 Pro Teardown: Schritt 10, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 10, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 10, Bild 3 von 3
      Precision Tweezers Set
      $11.95
      • We use a pair of tweezers to dig out the last bits behind the motherboard.
      • The missing piece: a small interconnect board for the power and volume buttons. We find the following chips:
      • IDT P9221 wireless power receiver
      • Lattice Semiconductor iCE40LM1K-CM36 iCE40 FPGA
      • Cirrus Logic CS35L35A audio amplifier
      • Texas Instruments LM3644 1.5 A camera flash LED driver
      • With the Mate's brains dissected, it's time to head towards the other end of the phone and check out its fancy footwork.
      Frag FixBot
    11. Huawei Mate 20 Pro Teardown: Schritt 11, Bild 1 von 2 Huawei Mate 20 Pro Teardown: Schritt 11, Bild 2 von 2
      • SIM trays aren't ordinarily exciting, but this tray happens to support a new memory card format called nano memory (NM).
      • The new NM cards are nano-SIM sized expandable memory (45% smaller than a normal SD card) and can offer a maximum read speed of 95 MB/s.
      • Huawei makes the NM cards themselves, eliminating potential phone slowdown due to low-quality SD cards.
      • The smaller format also allows this SIM/NM tray to be smaller than a traditional dual-card tray.
      Frag FixBot
    12. Huawei Mate 20 Pro Teardown: Schritt 12, Bild 1 von 2 Huawei Mate 20 Pro Teardown: Schritt 12, Bild 2 von 2
      • Just like in the P20 Pro, the USB-C charging port is mounted to a large flex cable. This means if the charging port fails, you'll only have to replace the main cable—instead of a more expensive daughterboard, as in the Google Pixel 3 XL.
      • Another similarity to the P-Series: no 3.5 mm headphone jack. USB-C headphones are included along with a 3.5 mm adapter.
      • Yet, the Mate 20 and Mate 20 Lite both still have a headphone jack. Maybe Huawei isn't quite sure if USB-C alone is the future.
      • The other port, a SIM reader, is mounted to a small board, and planted near the coin-style vibration motor.
      Frag FixBot
    13. Huawei Mate 20 Pro Teardown: Schritt 13, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 13, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 13, Bild 3 von 3
      iOpener
      $24.95
      • Moving swiftly along, we take a closer look at the Mate's power plant.
      • To our surprise, we find some orange pull tabs on the left side of the battery, containing a short guide how to remove it—we love guides!
      • We're happy whenever we can extract a battery without having to break out our iFixit Adhesive Remover—in this case, we just needed a little help from an iOpener to unseat it.
      • The battery weighs in at an unprecedented 16.04 Wh (4,200 mAh at 3.82 V).
      • In terms of raw capacity, that beats just about everyone—including its predecessor (15.28 Wh), the iPhone XS Max (12.08 Wh), and even heavyweight Samsung Galaxy Note9 (15.4 Wh).
      Frag FixBot
    14. Huawei Mate 20 Pro Teardown: Schritt 14, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 14, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 14, Bild 3 von 3
      iFixit Opening Picks (Set of 6)
      $4.95
      • We unleash a multi-headed heat-gun serpent—we named it Pat—which blasts through the curved display's IP68-rated adhesive.
      • There is one last big secret we need to explore to give Huawei's newest fighter a ranking—the 3120 x 1440 pixel, 19.5:9 ratio (~538 ppi density) display!
      • For the numbers fans: the iPhone XS has 2436 x 1125 pixels (~458 ppi), the XS Max has 2688 x 1242 pixels (~458 ppi), the Pixel 3 XL has 2960 x 1440 pixels (~523 ppi), and the S9+ has 2960 x 1440 pixels (~529 ppi).
      • An opening pick or eleven dramatically improves this smartphone's aerodynamics, and helps us pry up the display.
      Frag FixBot
    15. Huawei Mate 20 Pro Teardown: Schritt 15, Bild 1 von 3 Huawei Mate 20 Pro Teardown: Schritt 15, Bild 2 von 3 Huawei Mate 20 Pro Teardown: Schritt 15, Bild 3 von 3
      • Thought we were done already? Not yet! Last, but certainly not least, let's take a closer look at Huawei's new finger-reading tech.
      • The fingerprint sensor is made by Goodix and sits under the AMOLED panel, though Goodix markets the tech as an "in-display fingerprint sensor™".
      • The fingerprint flex cable contains a Goodix GM181 fingerprint controller.
      • The sensor isn't capacitive (like most familiar sensors such as Touch ID), but optical. This is reportedly similar to the sensor found in the new OnePlus 6T.
      • The sensor looks at your finger, which is illuminated by light from the display. Then the sensor uses the information it captures to create an image of the distinctive valleys and ridges of your fingerprint.
      • And underneath the display: a Synaptics S3718 touchscreen controller.
      Frag FixBot
    16. Huawei Mate 20 Pro Teardown: Schritt 16, Bild 1 von 1
      • That's it! The fight is finished, and we retreat to our corner. There will always be new challengers in the smartphone market, but this round is now at an end.
      • If you would like a nifty wallpaper as a souvenir, you can find one here!
      • Wanna be the first to break the teardown news? Sign up for our press list and get the inside scoop!
      Frag FixBot
    17. Fazit
      • Many components are modular and can be replaced independently.
      • Battery replacement requires removing only the back panel and midframe.
      • Only standard Phillips screws are used along with an average amount of adhesive.
      • Because of the sandwich build around the motherboard, there are more flex connectors than average and repairs will consume more time.
      • Glued-down front and back glass means greater risk of breakage while making repairs difficult to start.
      • Screen repairs require a lot of disassembly while battling tough adhesive.
      • A broken screen probably means you need to replace the fingerprint reader as well, or vice versa.
      Reparierbarkeits-Index
      4
      Reparierbarkeit 4 von 10
      (10 ist am einfachsten zu reparieren)
Tobias Isakeit
134.940 Reputation
189 Anleitungen geschrieben
Tobias Isakeit - Repairability Engineer Mitglied von Tobias Isakeit - Repairability Engineer
Business
1 Mitglied
1.924 Anleitungen geschrieben
38 Kommentare zur Anleitung
Hi. May I know if there are any waterproofing seals or gaskets around the power /volume buttons? Something similar to the note 7?
Ken S. - Antwort Teilen
It isn’t possible to see if there’s an extra plate with gaskets like in the Note 7 or the P20 Pro because of the mid frame plastic, that covers the volume and power buttons. We assume that the pins of the buttons run through a tight fit hole in the frame and there’s possibly a small rubber ring or gasket to guarantee the IP68 rating.
Dominik Schnabelrauch - Antwort Teilen
where is the loudspeaker?
Chao Shu - Antwort Teilen
The loudspeaker sits on top of the USB-C charging port and the SIM/NM card try. You can see it in the last picture bottom left.
When will you be doing a teardown of the Mate 20X? I’d like to see that!
Will - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 65
Letzte 30 Tage: 298
Insgesamt: 137,956
